[Swift-devel] Re: Need precise throttle on local provider
    Mihael Hategan
    hategan at mcs.anl.gov
    Tue Oct  5 16:14:34 CDT 2010
On Tue, 2010-10-05 at 16:06 -0500, Justin M Wozniak wrote:
> On Tue, 5 Oct 2010, Michael Wilde wrote:
> > ----- "Mihael Hategan" <hategan at mcs.anl.gov> wrote:
> >> On Tue, 2010-10-05 at 11:59 -0600, wilde at mcs.anl.gov wrote:
> >>> This code sets SWIFT_JOB_SLOT and SWOFT_WORKER_PID in the environment
> >>> of executed app() jobs.
> >> Right. I see no reason why those couldn't be there. But if you commit
> >> it to coasters, can you change to COASTER_JOB_SLOT?
> > In my application thats not feasible, as the application scripts should
> > work the same (and do) regardless of whether they were run under
> > coasters (where the provider sets the slot) or under the local exec
> > provider (where the slot is set by using multiple sites and the ENV
> > profile).
> COG_SMP_SLOT ?
Sounds more appropriate, but whatever works for you.
Mihael
