[Swift-devel] misassignment of jobs
    Michael Wilde
    wilde at mcs.anl.gov
    Sun Nov 21 19:37:18 CST 2010
OK, re bug 2: I didnt connect the symptoms of this issue with your earlier comments on timeouts, and just verified that you are correct: with the same extended timeouts I was using to try to keep a persistent coaster service up for an extended time, the failing case for bug 2 works.
I'll try to reproduce bug 1 now, then 3.
- Mike
----- Original Message -----
> On Sun, 2010-11-21 at 17:10 -0600, Michael Wilde wrote:
> > Mihael,
> > If you're in fixin' mode,
> I've been in fixin' mode for the past two months :)
> >  I'll spend some time now trying to reproduce the 3 coaster problems
> >  that are high on my "needed for users" list:
> > 1. Swift hangs/fails talking to persistent server if it sites idle
> > for
> > a few minutes, even with large timeout values (which were possibly
> > not
> > set correctly or fully).
> > 2. With normal coaster mode, if workers start toiming out for lack
> > of work, the Swift run dies.
> That one is addressed by removing the worker timeout. As I mentioned
> in
> a previous email, that timeout is a artifact of an older worker
> management scheme.
> > 3. Errors in provider staging at high volume.
> > If you already have test cases for these issues, let me know, and
> > I'll
> > focus on the missing ones. But Im assuming for now you need all
> > three.
> I have test cases for 1 and 3. I couldn't reproduce the problems so
> far.
> Mihael
Michael Wilde
Computation Institute, University of Chicago
Mathematics and Computer Science Division
Argonne National Laboratory
