[Swift-devel] misassignment of jobs
    Mihael Hategan
    hategan at mcs.anl.gov
    Thu Nov 18 17:39:30 CST 2010
Ok. I can see a couple of code paths that can lead to this, but I need
to constrain it some more.
Does this happen every time you run this?
Mihael
On Thu, 2010-11-18 at 16:08 -0600, Allan Espinosa wrote:
> i'm using a file named tc.data
> 2010-11-17 15:38:50,115-0600 INFO  unknown Using tc.data: tc.data
> $cat tc.data
> PADS  sleep_pads     /bin/sleep      INSTALLED INTEL32::LINUX
> GLOBUS::maxwalltime="00:05:00"
> BNL-ATLAS_gridgk01.racf.bnl.gov  worker0
> /usatlas/OSG/engage-scec/worker.pl      INSTALLED INTEL32::LINUX
> GLOBUS::maxwalltime="02:00:00"
> BNL-ATLAS_gridgk01.racf.bnl.gov  sleep0  /bin/sleep
> INSTALLED INTEL32::LINUX GLOBUS::maxwalltime="00:05:00"
> BNL-ATLAS_gridgk01.racf.bnl.gov  sleep            /bin/sleep
> BNL-ATLAS_gridgk02.racf.bnl.gov  worker1
> BNL-ATLAS_gridgk02.racf.bnl.gov  sleep1  /bin/sleep
> BNL-ATLAS_gridgk02.racf.bnl.gov  sleep            /bin/sleep
> FNAL_FERMIGRID_fnpcosg1.fnal.gov  worker2
> /grid/app/engage/scec/worker.pl      INSTALLED INTEL32::LINUX
> FNAL_FERMIGRID_fnpcosg1.fnal.gov  sleep2  /bin/sleep
> FNAL_FERMIGRID_fnpcosg1.fnal.gov  sleep            /bin/sleep
> Firefly_ff-grid3.unl.edu  worker3
> /panfs/panasas/CMS/app/engage/scec/worker.pl      INSTALLED
> INTEL32::LINUX GLOBUS::maxwalltime="02:00:00"
> Firefly_ff-grid3.unl.edu  sleep3  /bin/sleep
> Firefly_ff-grid3.unl.edu  sleep            /bin/sleep
> GridUNESP_CENTRAL_ce.grid.unesp.br  worker4 /osg/app/worker.pl
> INSTALLED INTEL32::LINUX GLOBUS::maxwalltime="02:00:00"
> GridUNESP_CENTRAL_ce.grid.unesp.br  sleep4  /bin/sleep
> GridUNESP_CENTRAL_ce.grid.unesp.br  sleep            /bin/sleep
> LIGO_UWM_NEMO_osg-nemo-ce.phys.uwm.edu  worker5
> /opt/osg/app/engage/scec/worker.pl      INSTALLED INTEL32::LINUX
> LIGO_UWM_NEMO_osg-nemo-ce.phys.uwm.edu  sleep5  /bin/sleep
> LIGO_UWM_NEMO_osg-nemo-ce.phys.uwm.edu  sleep            /bin/sleep
> MIT_CMS_ce01.cmsaf.mit.edu  worker6 /osg/app/engage/scec/worker.pl
> MIT_CMS_ce01.cmsaf.mit.edu  sleep6  /bin/sleep
> MIT_CMS_ce01.cmsaf.mit.edu  sleep            /bin/sleep
> MIT_CMS_ce02.cmsaf.mit.edu  worker7 /osg/app/engage/scec/worker.pl
> MIT_CMS_ce02.cmsaf.mit.edu  sleep7  /bin/sleep
> MIT_CMS_ce02.cmsaf.mit.edu  sleep            /bin/sleep
> NYSGRID_CORNELL_NYS1_nys1.cac.cornell.edu  worker8
> /grid-tmp/grid-apps/engage/scec/worker.pl      INSTALLED
> NYSGRID_CORNELL_NYS1_nys1.cac.cornell.edu  sleep8  /bin/sleep
> NYSGRID_CORNELL_NYS1_nys1.cac.cornell.edu  sleep            /bin/sleep
> Nebraska_gpn-husker.unl.edu  worker9
> Nebraska_gpn-husker.unl.edu  sleep9  /bin/sleep
> Nebraska_gpn-husker.unl.edu  sleep            /bin/sleep
> Nebraska_red.unl.edu  worker10 /opt/osg/app/engage/scec/worker.pl
> Nebraska_red.unl.edu  sleep10  /bin/sleep                  INSTALLED
> Nebraska_red.unl.edu  sleep            /bin/sleep
> Prairiefire_pf-grid.unl.edu  worker11
> /opt/pfgridapp/engage/scec/worker.pl      INSTALLED INTEL32::LINUX
> Prairiefire_pf-grid.unl.edu  sleep11  /bin/sleep
> Prairiefire_pf-grid.unl.edu  sleep            /bin/sleep
> Purdue-RCAC_osg.rcac.purdue.edu  worker12
> /apps/osg/engage/scec/worker.pl      INSTALLED INTEL32::LINUX
> Purdue-RCAC_osg.rcac.purdue.edu  sleep12  /bin/sleep
> Purdue-RCAC_osg.rcac.purdue.edu  sleep            /bin/sleep
> RENCI-Engagement_belhaven-1.renci.org  worker13
> /nfs/osg-app/engage/scec/worker.pl      INSTALLED INTEL32::LINUX
> RENCI-Engagement_belhaven-1.renci.org  sleep13  /bin/sleep
> RENCI-Engagement_belhaven-1.renci.org  sleep            /bin/sleep
> SBGrid-Harvard-East_osg-east.hms.harvard.edu  worker14
> /osg/storage/app/engage/scec/worker.pl      INSTALLED INTEL32::LINUX
> SBGrid-Harvard-East_osg-east.hms.harvard.edu  sleep14  /bin/sleep
> SPRACE_osg-ce.sprace.org.br  worker15 /osg/app/engage/scec/worker.pl
> SPRACE_osg-ce.sprace.org.br  sleep15  /bin/sleep
> SPRACE_osg-ce.sprace.org.br  sleep            /bin/sleep
> UCHC_CBG_vdgateway.vcell.uchc.edu  worker16
> UCHC_CBG_vdgateway.vcell.uchc.edu  sleep16  /bin/sleep
> UCHC_CBG_vdgateway.vcell.uchc.edu  sleep            /bin/sleep
> UCR-HEP_top.ucr.edu  worker17
> /data/bottom/osg_app/engage/scec/worker.pl      INSTALLED
> UCR-HEP_top.ucr.edu  sleep17  /bin/sleep                  INSTALLED
> UCR-HEP_top.ucr.edu  sleep            /bin/sleep
> UFlorida-HPC_osg.hpc.ufl.edu  worker18 /osg/app/engage/scec/worker.pl
> UFlorida-HPC_osg.hpc.ufl.edu  sleep18  /bin/sleep
> UFlorida-HPC_osg.hpc.ufl.edu  sleep            /bin/sleep
> UFlorida-PG_pg.ihepa.ufl.edu  worker19
> /raid/osgpg/pg/app/engage/scec/worker.pl      INSTALLED INTEL32::LINUX
> UFlorida-PG_pg.ihepa.ufl.edu  sleep19  /bin/sleep
> UFlorida-PG_pg.ihepa.ufl.edu  sleep            /bin/sleep
> UMissHEP_umiss001.hep.olemiss.edu  worker20
> /osgremote/osg_app/engage/scec/worker.pl      INSTALLED INTEL32::LINUX
> UMissHEP_umiss001.hep.olemiss.edu  sleep20  /bin/sleep
> UMissHEP_umiss001.hep.olemiss.edu  sleep            /bin/sleep
> UTA_SWT2_gk04.swt2.uta.edu  worker21
> /cluster/grid/app/engage/scec/worker.pl      INSTALLED INTEL32::LINUX
> UTA_SWT2_gk04.swt2.uta.edu  sleep21  /bin/sleep
> UTA_SWT2_gk04.swt2.uta.edu  sleep            /bin/sleep
> WQCG-Harvard-OSG_tuscany.med.harvard.edu  worker22
> WQCG-Harvard-OSG_tuscany.med.harvard.edu  sleep22  /bin/sleep
> WQCG-Harvard-OSG_tuscany.med.harvard.edu  sleep            /bin/sleep
> 2010/11/18 Mihael Hategan <hategan at mcs.anl.gov>:
> > I'm sure there is a reasonable explanation for this.
> > Can you post your entire tc.data? And to make sure we're talking about
> > the right one, can you look at the swift log and use exactly the one
> > that swift claims is using?
> > Mihael
> > On Thu, 2010-11-18 at 14:39 -0600, Allan Espinosa wrote:
> >> tc.data for worker15:
> >> But it was assigned to another site instead:
> >> $ grep 0erqqq1k worker-*.log
> >> 2010-11-17 15:38:58,804-0600 DEBUG vdl:execute2 THREAD_ASSOCIATION
> >> jobid=worker15-0erqqq1k thread
> >>  host=LIGO_UWM_NEMO_osg-nemo-ce.phys.uwm.edu replicationGroup=2pnqqq1k
> >> 2010-11-17 15:38:59,110-0600 INFO  vdl:createdirset START
> >> jobid=worker15-0erqqq1k host=LIGO_UWM_N
> >> ce.phys.uwm.edu - Initializing directory structure
> >> 2010-11-17 15:38:59,137-0600 INFO  vdl:createdirset END
> >> jobid=worker15-0erqqq1k - Done initializi
> >> structure
> >> 2010-11-17 15:38:59,172-0600 INFO  vdl:dostagein START
> >> jobid=worker15-0erqqq1k - Staging in files
> >> 2010-11-17 15:38:59,257-0600 INFO  vdl:dostagein END
> >> jobid=worker15-0erqqq1k - Staging in finishe
> >> 2010-11-17 15:38:59,323-0600 DEBUG vdl:execute2 JOB_START
> >> jobid=worker15-0erqqq1k tr=worker15 arg
> >> //128.135.125.17:61015, SPRACE_osg-ce.sprace.org.br, /tmp, 7200]
> >> tmpdir=worker-20101117-1538-fe9a
> >> orker15-0erqqq1k host=LIGO_UWM_NEMO_osg-nemo-ce.phys.uwm.edu
> >> 2010-11-17 15:39:01,394-0600 INFO  Execute Submit: in:
> >> worker-20101117-1538-fe9aq209 command: /bi
> >> /_swiftwrap worker15-0erqqq1k -jobdir 0 -scratch  -e worker15 -out
> >> stdout.txt -err stderr.txt -i
> >>  -k  -cdmfile  -status files -a http://128.135.125.17:61015
> >> SPRACE_osg-ce.sprace.org.br /tmp 7200
> >> 2010-11-17 15:39:01,394-0600 INFO  GridExec TASK_DEFINITION:
> >> Task(type=JOB_SUBMISSION, identity=u
> >> -1-1290029938030) is /bin/bash shared/_swiftwrap worker15-0erqqq1k
> >> .txt -err stderr.txt -i -d  -if  -of  -k  -cdmfile  -status files -a
> >> 2010-11-17 16:49:33,106-0600 DEBUG vdl:checkjobstatus START
> >> 2010-11-17 16:49:33,278-0600 INFO  vdl:checkjobstatus FAILURE
> >> jobid=worker15-0erqqq1k - Failure f
> >> 2010-11-17 16:49:38,180-0600 DEBUG vdl:execute2 APPLICATION_EXCEPTION
> >> jobid=worker15-0erqqq1k - A
> >> ception: Cannot find executable worker15 on site system path
> >> There is no entry for worker15 for the site LIGO_UWM_NEMO in my tc.data
> >> -Allan
