[Swift-devel] Concurrent dostagein calls limited to 8 ?
Mihael Hategan
hategan at mcs.anl.gov
Mon Nov 15 00:06:44 CST 2010
On Sun, 2010-11-14 at 23:24 -0600, Michael Wilde wrote:
> That explains a lot - the limited number of Karajan threads probably explains why coasters goes haywire in the larger tests as well.
> Clearly this should be done as full fledged provider. But that will take a fair bit more work.
> Would there be any ill effects from bumping up the number of karajan threads to see if I can make this demo work? WHere is that set?
There will be the ill effect of wasting memory to wait for stuff. It's
set in EventBus.java.
> Also, when you say "use the local provider or
> > some other scheme that can free the workers while the sub-processes
> > run." - do you have anything "quick and easy" in mind there?
Yep. Say task:execute(script, args) in vdl-int instead.
Mihael
