[Swift-devel] Re: Concurrent dostagein calls limited to 8 ?
    Mihael Hategan
    hategan at mcs.anl.gov
    Sun Nov 14 16:21:56 CST 2010
I need more info.
Some useful questions to answer:
- how many stage-ins are queued to the scheduler?
- how quick are the stage-ins?
- who (i.e. what code) starts the external.sh script and how?
In theory, if a sufficient number of tasks are queued then the only
limit (after my last commit) should be the throttles and whatever
inherent limits are in the mechanism used to implement the stage-ins.
Mihael
On Sun, 2010-11-14 at 16:12 -0600, Michael Wilde wrote:
> As far as I can tell its still showing the same behavior - only 8 stageins are active:
> wilde    17568 17564 17564  4873  0 16:05 pts/8    00:00:00             /bin/sh /scratch/local/wilde/swift/src/trunk/cog/modules/swift
> wilde    17632 17568 17564  4873  5 16:05 pts/8    00:00:09               java -Xmx256M -Djava.endorsed.dirs=/scratch/local/wilde/swif
> wilde    19193 17632 17564  4873  0 16:08 pts/8    00:00:00                 /bin/bash /home/wilde/swift/lab/go/external.sh getlanduse-
> wilde    19357 19193 17564  4873  0 16:08 pts/8    00:00:00                   sleep 3
> wilde    19198 17632 17564  4873  0 16:08 pts/8    00:00:00                 /bin/bash /home/wilde/swift/lab/go/external.sh getlanduse-
> wilde    19358 19198 17564  4873  0 16:08 pts/8    00:00:00                   sleep 3
> wilde    19205 17632 17564  4873  0 16:08 pts/8    00:00:00                 /bin/bash /home/wilde/swift/lab/go/external.sh getlanduse-
> wilde    19359 19205 17564  4873  0 16:08 pts/8    00:00:00                   sleep 3
> wilde    19210 17632 17564  4873  0 16:08 pts/8    00:00:00                 /bin/bash /home/wilde/swift/lab/go/external.sh getlanduse-
> wilde    19361 19210 17564  4873  0 16:08 pts/8    00:00:00                   sleep 3
> wilde    19214 17632 17564  4873  0 16:08 pts/8    00:00:00                 /bin/bash /home/wilde/swift/lab/go/external.sh getlanduse-
> wilde    19362 19214 17564  4873  0 16:08 pts/8    00:00:00                   sleep 3
> wilde    19218 17632 17564  4873  0 16:08 pts/8    00:00:00                 /bin/bash /home/wilde/swift/lab/go/external.sh getlanduse-
> wilde    19363 19218 17564  4873  0 16:08 pts/8    00:00:00                   sleep 3
> wilde    19224 17632 17564  4873  0 16:08 pts/8    00:00:00                 /bin/bash /home/wilde/swift/lab/go/external.sh getlanduse-
> wilde    19364 19224 17564  4873  0 16:08 pts/8    00:00:00                   sleep 3
> wilde    19240 17632 17564  4873  0 16:08 pts/8    00:00:00                 /bin/bash /home/wilde/swift/lab/go/external.sh getlanduse-
> wilde    19365 19240 17564  4873  0 16:08 pts/8    00:00:00                   sleep 3
> - Mike
> > My bad. Try cog trunk r2932.
> > Mihael
> > On Sun, 2010-11-14 at 12:45 -0600, Michael Wilde wrote:
> > > Im using Justin's new external CDM policy to talk to
> > > globusonline.org.
> > > Ive got the two IO throttles set to 30:
> > > throttle.transfers=30
> > > throttle.file.operations=30
> > > ...but I still see exactly 8 concurrent dostagein calls (as seen by
> > > calls to my external IO handler external.sh)
> > > Do you know what is limiting this concurrency to 8? I'd like to open
> > > it up much wider.
> > > My swift command and relevant files are below.
> > > Logs are in CI: /home/wilde/swift/demo/modis
> > > Thanks,
> > > Mike
> > > login1$ cat rundemo.go.local.sh
> > > rm -f external.*.log
> > > swift -config cf -tc.file tc.local -sites.file sites.local.xml
> > > -cdm.file fs.ftponly modis.go.swift -nfiles=30
> > > # -location= -n= -site==
> > > login1$ cat cf
> > > wrapperlog.always.transfer=true
> > > sitedir.keep=true
> > > execution.retries=0
> > > lazy.errors=false
> > > status.mode=provider
> > > use.provider.staging=false
> > > provider.staging.pin.swiftfiles=false
> > > login1$ cat sites.local.xml
> > > <config>
> > >   <pool handle="localhost">
> > >     <execution provider="local" url="none"/>
> > >     <profile namespace="karajan" key="jobThrottle">.63</profile>
> > >     <profile namespace="karajan" key="initialScore">10000</profile>
> > >     <filesystem provider="local"/>
> > >     <workdirectory>/home/wilde/swiftwork</workdirectory>
> > >   </pool>
> > > </config>
> > > login1$
> > > login1$ cat fs.ftponly
> > > rule .*gsiftp://.* EXTERNAL /home/wilde/swift/lab/go/external.sh
> > > login1$
