[Swift-devel] [Bug 6] Not globally unique temporary file names
    bugzilla-daemon at mcs.anl.gov
    Tue Nov  9 00:14:50 CST 2010
https://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=6
skenny <skenny at uchicago.edu> changed:
           What    |Removed                     |Added
             Status|ASSIGNED                    |RESOLVED
         Resolution|                            |FIXED
--- Comment #5 from skenny <skenny at uchicago.edu>  2010-11-09 00:14:49 ---
(In reply to comment #4)
> (In reply to comment #3)
> > this addresses ian's issue...then if i re-run it the output files produced are
> > given the same names (so they just overwrite the output from the previous run)
> > which, i *think* is what mihael was referring to (?)
> Right. Which is Ian's initial complaint.
> The question is whether you get the same behavior if you were to import that in
> a different script and repeatedly call that program, would it still work? I
> suspect that it now does
correct...it still works when you import the function from another script and
then call it repeatedly. thus it seems to have been resolved.
Configure bugmail: https://bugzilla.mcs.anl.gov/swift/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are watching the assignee of the bug.
You are watching the reporter.
