[Swift-devel] Fwd: [Swift-user] Question: Setting environment variables
David Kelly dk0966 at cs.ship.edu
Mon May 31 06:43:50 CDT 2010
Hello,
It looks like this issue has already been resolved. Inside
catalog/transformations/File.java, there is a regular expression which
should take care of any combination of tabs and spaces. I tested this out by
adding random spaces/tabs inside of tc.data. I will resolve the open bug for
this, #66, since it appears to have been fixed.
David
On Fri, May 28, 2010 at 1:17 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> On Fri, 2010-05-28 at 12:10 -0500, Michael Wilde wrote:
> > David, we should fix this whitespace issue in parsing tc.data. Its a
> > common problem that new users (and old) encounter.
> > We held off on this because the original code to parse that file comes
> > from the older VDS system and is now I think supported by Pegasus.
> > Either way, we should fix it: first see if Pegasus has it fixed; else
> > fix it ourselves and post them a fix.
> A while ago I removed the VDS dependency and extracted only the few
> files that we were using from there. They are now in the swift svn. So I
> don't think we have to bother with going through Pegasus, though a patch
> for them may be the nice thing to do.
> Mihael
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20100531/e025e532/attachment.html>
