[Swift-devel] Re: Notes on maintaining the swift web and docs
Mihael Hategan hategan at mcs.anl.gov
Thu May 27 12:43:01 CDT 2010
On Thu, 2010-05-27 at 02:39 -0400, David Kelly wrote:
> Then I followed a maze of symlinks to what I believe is the correct
> JAVA_HOME on this system (login.ci.uchicago.edu)
> at /usr/lib/jvm/jre-1.4.2-gcj
> Then I received the following errors:
gcj is almost never the correct JAVA_HOME.
You should find a proper JVM, such as the one from sun.
I believe that softenv has one of the Sun JVMs, but I forget the proper
incantation. Does anybody else know it?
Mihael
