[Swift-devel] swift tree getting build options from cog?
Allan Espinosa
aespinosa at cs.uchicago.edu
Mon May 24 20:52:06 CDT 2010
It seems that swift-trunk depends on specific cog-trunk coasters
classes that are not compatible and thus still breaks the build:
[echo] [swift]: COMPILE
[mkdir] Created dir: /autonfs/home/aespinosa/swift/cogkit/modules/swift/buil
d
[javac] Compiling 357 source files to /autonfs/home/aespinosa/swift/cogkit/m
odules/swift/build
[javac] /autonfs/home/aespinosa/swift/cogkit/modules/swift/src/org/globus/sw
ift/data/policy/AllocationHook.java:6: cannot find symbol
[javac] symbol : class Hook
[javac] location: package org.globus.cog.abstraction.coaster.service.job.man
ager
[javac] import org.globus.cog.abstraction.coaster.service.job.manager.Hook;
[javac] ^
[javac] /autonfs/home/aespinosa/swift/cogkit/modules/swift/src/org/globus/swift/data/policy/AllocationHook.java:13:
cannot find symbol
[javac] symbol: class Hook
[javac] public class AllocationHook extends Hook
[javac] ^
[javac] /autonfs/home/aespinosa/swift/cogkit/modules/swift/src/org/griphyn/vdl/karajan/lib/Execute.java:37:
cannot find symbol
[javac] symbol : variable C_STAGEIN
[javac] location: class org.griphyn.vdl.karajan.lib.Execute
[javac] A_REPLICATION_CHANNEL,
A_JOBID, C_STAGEIN, C_STAGEOUT, C_CLEANUP });
[javac] ^
cannot find symbol
[javac] symbol : variable C_STAGEOUT
[javac]
cannot find symbol
[javac] symbol : variable C_CLEANUP
[javac]
[javac] Note: Some input files use or override a deprecated API.
[javac] Note: Recompile with -Xlint:deprecation for details.
[javac] Note: Some input files use unchecked or unsafe operations.
[javac] Note: Recompile with -Xlint:unchecked for details.
2010/5/24 Mihael Hategan <hategan at mcs.anl.gov>:
> Re: [Swift-devel] swift tree getting build options from cog?
> That's right. Edit modules/../mbuild.xml and change force.java.version
> to 1.5.
> On Mon, 2010-05-24 at 20:04 -0500, Allan Espinosa wrote:
