[Swift-devel] swift-plot-log parsing errors
Ben Clifford benc at hawaga.org.uk
Mon May 10 02:35:52 CDT 2010
> info-and-karajan-actives
That's right before the errors.
Here's what its documented as doing (at least in r3264) at the top:
# for every job which has an info file,
# create two columns, one being the start time of the job according
# to the info file and the other being the Active time according to
# karajan
It needs both info files and a successfully generated execute2.event file,
by the looks of it (and possibly other files).
This file may be irrelevant to you and so you can perhaps stop it being
generated. The purpose of it was to get some feeling for how well the
live-reported job-active notifications match up with the post-run
collected info files. Depending on the execution path from CoG to the
worker node (eg gram and the queueing system), there could be very large
time differences (in either direction). The -info files are generally more
accurate but you don't know them during the run. The live reported
notifications were used to update eg. the console status ticker - but if
the underlying notifications are wrong then the ticker is also wrong.
http://www.hawaga.org.uk/ben/
