[Swift-devel] error in reading in files over gridftp
    Mihael Hategan
    hategan at mcs.anl.gov
    Wed Mar 24 17:02:48 CDT 2010
What happens if you add another forward slash after ".edu"?
On Wed, 2010-03-24 at 16:31 -0500, Allan Espinosa wrote:
> The file gets created in the work directory (probably via touch) but
> has 0 bytes for size.
> type messagefile;
> (messagefile o) write(messagefile i) {
>     app {
>         echo @filename(i) stdout=@filename(o);
> messagefile infile
> <"gsiftp://ff-grid.unl.edu//panfs/panasas/CMS/data/engage/swift/071-singlefilemapper-input.in">;
> messagefile outfile <"071-singlefilemapper-input.out">;
> outfile = write(infile);
> session (with vanilla sites.xml):
> swift-r3264 cog-r2728
> RunID: test
> Progress:
> Progress: Failed but can retry:1
> Failed to transfer wrapper log from
> 071-singlefilemapper-input-test/info/e on localhost
> 071-singlefilemapper-input-test/info/g on localhost
> Progress:  Stage in:1
> 071-singlefilemapper-input-test/info/i on localhost
> Execution failed:
>         Exception in echo:
> Arguments: [panfs/panasas/CMS/data/engage/swift/071-singlefilemapper-input.in]
> Host: localhost
> Directory: 071-singlefilemapper-input-test/jobs/i/echo-ic8o7kpj
> stderr.txt:
> stdout.txt:
> Caused by:
>         Exception in getFile
> Caused by:
>         Server refused performing the request. Custom message:  (error
> code 1) [Nested exception message:  Custom message: Unexpected reply:
> 500 Command failed]
> What command does getFile issue?  I can download the file manually via
> globus-url-copy or uberftp
> the logfile is also attached in this email.
> thanks!
> -Allan
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
