[Swift-devel] Re: simple_mapper auto-padding of "."
Allan Espinosa aespinosa at cs.uchicago.edu
Sat Mar 20 03:31:58 CDT 2010
I'll be getting my cookies now :)
Patch available in
http://www.ci.uchicago.edu/~aespinosa/swift_mapper-noauto.patch
Test cases/ examples in
tests/language-behaviour/T078-simplemapper-nosuffix.swift and
tests/language-behaviour/T078-simplemapper-nosuffix.swift (Did i get
the exception handling practice correctly?)
diff --git a/src/org/griphyn/vdl/mapping/file/AbstractFileMapper.java
b/src/org/griphyn/vdl/mapping/file/AbstractF
index 362cb01..5b7b455 100644
--- a/src/org/griphyn/vdl/mapping/file/AbstractFileMapper.java
+++ b/src/org/griphyn/vdl/mapping/file/AbstractFileMapper.java
@@ -12,6 +12,7 @@ import org.apache.log4j.Logger;
 import org.griphyn.vdl.mapping.AbsFile;
 import org.griphyn.vdl.mapping.AbstractMapper;
+import org.griphyn.vdl.mapping.InvalidMappingParameterException;
 import org.griphyn.vdl.mapping.MappingParam;
 import org.griphyn.vdl.mapping.Path;
 import org.griphyn.vdl.mapping.PhysicalFormat;
@@ -36,6 +37,8 @@ import org.griphyn.vdl.mapping.PhysicalFormat;
   *                  this string. If suffix does not begin with a '.'
   *                  character, then a '.' will be added automatically to
   *                  separate the rest of the filename from the suffix</li>
+  *   <li>noauto - if specified as "true", then the suffix auto
addition of a'.'
+  *                  will be disabled.  Default value is "false".</li>
   *   <li>pattern - if specified, then filenames will be selected from
   *                 the location directory when they match the unix glob
   *                 pattern supplied in this parameter.</li>
@@ -47,6 +50,7 @@ public abstract class AbstractFileMapper extends
AbstractMapper {
        public static final MappingParam PARAM_SUFFIX = new
MappingParam("suffix", null);
        public static final MappingParam PARAM_PATTERN = new
MappingParam("pattern", null);
        public static final MappingParam PARAM_LOCATION = new
MappingParam("location", null);
+       public static final MappingParam PARAM_NOAUTO = new
MappingParam("noauto", "false");
        public static final Logger logger =
Logger.getLogger(AbstractFileMapper.class);
@@ -79,7 +83,12 @@ public abstract class AbstractFileMapper extends
AbstractMapper {
                super.setParams(params);
                if (PARAM_SUFFIX.isPresent(this)) {
                        String suffix = PARAM_SUFFIX.getStringValue(this);
-                       if (!suffix.startsWith(".")) {
+                       String noauto = PARAM_NOAUTO.getStringValue(this);
+                       if (!noauto.equals("true") && !noauto.equals("false")) {
+                               throw new
InvalidMappingParameterException("noauto parameter was set to 'true'
or
+                                               ". Value set was '" +
noauto + "'");
+                       if (!suffix.startsWith(".") && noauto.equals("false")) {
                                PARAM_SUFFIX.setValue(this, "." + suffix);
...skipping...
+(messagefile t) write() {
+    app {
+        echo @filename(t) stdout=@filename(t);
+messagefile outfile <simple_mapper;
+                     prefix="T078-simplemapper-nosuffix", noauto="true",
+                     suffix="_nodot.out">;
+outfile = write();
diff --git a/tests/language-behaviour/T078-simplemapper-nosuffix_nodot.out.expected
b/tests/language-behaviour/T07
new file mode 100644
index 0000000..4d96d92
--- /dev/null
+++ b/tests/language-behaviour/T078-simplemapper-nosuffix_nodot.out.expected
@@ -0,0 +1 @@
+T078-simplemapper-nosuffix_nodot.out
diff --git a/tests/language-behaviour/T079-simplemapper-nosuffix_exception.swift
b/tests/language-behaviour/T079-s
index 0000000..d7223ef
--- /dev/null
+++ b/tests/language-behaviour/T079-simplemapper-nosuffix_exception.swift
@@ -0,0 +1,16 @@
+// this one is like test T078-simplemapper-nosuffix, but demonstrates the
+// mapping exception on invalid values
+type messagefile;
+    app {
+                     prefix="T078-simplemapper-nosuffix", noauto="exception",
+outfile = write();
[aespinosa at login2 swift]$ git diff master > ~/public_html/
.__acl                           index.html                       swift/
adopters_espinosa.pdf            jgi_blastp.tar.gz
swiftplot_svg-r2874.patch
bigdata/                         jobdirpath.tar.gz
swift_r2846_bgp.patch
blastp/                          log
test-20090124-0019-je79k4q4.log
dag.svg                          MosaStore-v0.8.09.tar.gz
to_jr_and_syrah.ogg
.DS_Store                        mpi-collective/                  top_vanilla.gz
espinosa_swift.tar.gz            mtdm/                            visual/
falkon/                          provider-coaster-cpu_fix.patch   workflow.svg
flow.png                         run4-trace.tgz
[aespinosa at login2 swift]$ git diff master > ~/public_html/mapper_noauto.patch
[aespinosa at login2 swift]$ cat ~/public_html/mapper_noauto.patch
addition of a'.'
AbstractMapper {
AbstractMapper {
+				throw new InvalidMappingParameterException("noauto parameter was
set to 'true' or 'false'" +
+						". Value set was '" + noauto + "'");
diff --git a/tests/language-behaviour/T078-simplemapper-nosuffix.swift
b/tests/language-behaviour/T078-simplemapper-nosuffix.swift
index 0000000..55c80de
--- /dev/null
+++ b/tests/language-behaviour/T078-simplemapper-nosuffix.swift
@@ -0,0 +1,17 @@
+// this one is like test 073-simplemapper, but doesn't
+// add the missing dot in front of the suffix
+type messagefile;
+    app {
+outfile = write();
--- /dev/null
@@ -0,0 +1 @@
--- /dev/null
@@ -0,0 +1,16 @@
+type messagefile;
+    app {
+outfile = write();
Enjoy!
-Allan
2010/3/19 Mihael Hategan <hategan at mcs.anl.gov>:
> On Fri, 2010-03-19 at 12:51 -0500, Allan Espinosa wrote:
>> Never mind.
>> I found the code that does the padding.  I'll just comment it out in
>> my Swift build
> Or you could add a parameter to do so in exchange for karma or imaginary
> cookies :)
Allan M. Espinosa <http://amespinosa.wordpress.com>
PhD student, Computer Science
University of Chicago <http://people.cs.uchicago.edu/~aespinosa>
