[Swift-devel] coasters and java on queen bee
    Sarah Kenny
    skenny at uchicago.edu
    Mon Jun 28 14:34:07 CDT 2010
tc.data had no effect...will try sites
On Mon, Jun 28, 2010 at 2:30 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> Have you tried setting JAVA_HOME in tc.data or sites.xml? I have a
> suspicion that might work.
> On Mon, 2010-06-28 at 14:11 -0500, Sarah Kenny wrote:
>> anyone else get this using coasters on queen bee?
>> STDOUT: Warning: -jar not understood. Ignoring.
>> Exception in thread "main" java.lang.NoClassDefFoundError: .tmp.bootstrap.Z29712
>>    at gnu.gcj.runtime.FirstThread.run() (/usr/lib64/libgcj.so.5.0.0)
>>    at _Jv_ThreadRun(java.lang.Thread) (/usr/lib64/libgcj.so.5.0.0)
>>    at _Jv_RunMain(java.lang.Class, byte const, int, byte const,
>> boolean) (/usr/lib64/libgcj.so.5.0.0)
>>    at __gcj_personality_v0 (/home/skenny/java.version=1.4.2)
>>    at __libc_start_main (/lib64/tls/libc-2.3.4.so)
>>    at _Jv_RegisterClasses (/home/skenny/java.version=1.4.2)
>> not sure why it's showing my java version as 1.4.2...when i'm logged
>> into the headnode (or a worker node) my java version is much newer:
>> [skenny at qb1 ~]$ java -version
>> java version "1.6.0_20"
>> Java(TM) SE Runtime Environment (build 1.6.0_20-b02)
>> Java HotSpot(TM) 64-Bit Server VM (build 16.3-b01, mixed mode)
>> i also tried adding JAVA_HOME to my .bashrc on the site which had no effect.
>> any idea how i can get swift to use the right java?
>> using a slightly older swift (swift-r3116 cog-r2482)...don't know if
>> this has maybe been fixed in a later version (?)
>> thanks
>> ~sk
>> Swift-devel mailing list
>> Swift-devel at ci.uchicago.edu
>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
