[Swift-devel] coasters and java on queen bee
    Sarah Kenny
    skenny at uchicago.edu
    Mon Jun 28 14:11:44 CDT 2010
anyone else get this using coasters on queen bee?
STDOUT: Warning: -jar not understood. Ignoring.
Exception in thread "main" java.lang.NoClassDefFoundError: .tmp.bootstrap.Z29712
   at gnu.gcj.runtime.FirstThread.run() (/usr/lib64/libgcj.so.5.0.0)
   at _Jv_ThreadRun(java.lang.Thread) (/usr/lib64/libgcj.so.5.0.0)
   at _Jv_RunMain(java.lang.Class, byte const, int, byte const,
boolean) (/usr/lib64/libgcj.so.5.0.0)
   at __gcj_personality_v0 (/home/skenny/java.version=1.4.2)
   at __libc_start_main (/lib64/tls/libc-2.3.4.so)
   at _Jv_RegisterClasses (/home/skenny/java.version=1.4.2)
not sure why it's showing my java version as 1.4.2...when i'm logged
into the headnode (or a worker node) my java version is much newer:
[skenny at qb1 ~]$ java -version
java version "1.6.0_20"
Java(TM) SE Runtime Environment (build 1.6.0_20-b02)
Java HotSpot(TM) 64-Bit Server VM (build 16.3-b01, mixed mode)
i also tried adding JAVA_HOME to my .bashrc on the site which had no effect.
any idea how i can get swift to use the right java?
using a slightly older swift (swift-r3116 cog-r2482)...don't know if
this has maybe been fixed in a later version (?)
thanks
~sk
