[Swift-devel] May need VOMS proxy for many OSG sites
    Allan Espinosa
    aespinosa at cs.uchicago.edu
    Thu Jun 17 14:49:01 CDT 2010
Some sites ignore VOMS information (which should not be the case).  I
was running jobs the other day on BNL-ATLAS with my proxy including
Engage voms attributes.  I get permission errors in accessing
engage-user files because my jobs were being executed on the 'osgedu'
VO.    I still have a couple of open tickets in OSG support because of
that.
What I suggest is that you query sites that supports the VO you think
your proxy defaults to (without the VOMS attributes).  Then
incrementally check sites per batch of VOs
-Allan
2010/6/17 Michael Wilde <wilde at mcs.anl.gov>:
> Arjun, this may be the reason that your access to many OSG sites is failing.
> Find a site that fails using grid-proxy-init from say teraport.
> Then try that same site, using voms-proxy-init (sp?) on engage-login.
> We'll both need to dig into the full meaning of a "VOMS" proxy, but basically it appends extra "role" information to the proxy to indicate that you are activing as a member of a specific VO (in your case, the "engage" VO).
> I dont recall if we added that to Swift yet (I think not). Mihael, do you recal?
> If not, you'll need to do more of the initial testing from engage-login until we instal; OSG clients.
> - Mike
> ----- Forwarded Message -----
> From: "Brian Bockelman" <bbockelm at cse.unl.edu>
> To: "Robert Engel" <engel_r at ligo.caltech.edu>
> Cc: "Keith Chadwick" <chadwick at fnal.gov>, "Iwona Sakrejda" <isakrejda at lbl.gov>, OSG-int at opensciencegrid.org, OSG-VO-FORUM at opensciencegrid.org, "Arvind Gopu" <agopu at indiana.edu>, "Rob Quick" <rquick at iupui.edu>
> Sent: Thursday, June 17, 2010 2:44:16 AM GMT -06:00 US/Canada Central
> Subject: Re: How to know if a site requires a VOMS Proxy or a Grid Proxy for authentication?
> On Jun 17, 2010, at 12:39 AM, Robert Engel wrote:
>> Keith,
>>   thanks for the link. But that is what I meant by manually knocking on each door. As an OSG user I want a simple way to find out what proxy to use on each of the potential 50+ resources there are.
> Use a VOMS proxy.  Didn't we just determine they are a superset of grid proxies?  Reading through the thread, I didn't see any site saying "I accept grid proxies but not VOMS proxies."
> Ultimately, there are a million things that can go wrong in distributed computing (cosmic rays hitting fiber cables at FNAL).  Why concentrate on this one?  I'm not against having better probes or tests - but we have extremely limited effort.  I'd rather identify the areas where we need this the most.
> The only way to know if a site accepts your jobs are to submit jobs.  Why should we add central complexity instead of using auto-discovery (esp since the central view, whether MyOSG, BDII, etc, is always going to be wrong as they don't use your proxy)?
> We are a decentralized, distributed computing facility.  You can't have centralized information that's "correct" if you have a decentralized computing system.
> Brian
>> I am thinking that myOSG could provide the required proxy information for each of the resources. Perhaps Arvind and Rob can comment on that.
>> Robert
>> Keith Chadwick wrote:
>>> At 3:17 PM -0700 6/16/10, Robert Engel wrote:
>>>> Hey Iwona,
>>>>   currently I recommend in the documentation to always check with the membership VO if they support VOMS and provide a VOMS server. Just as you said, the VOMS proxy in the end is just a 'fancy' grid proxy and can be used as such. I recommend using the VOMS Proxy under this circumstances.
>>>> On the other hand I would like users who can't generate a VOMS Proxy with extended attributes to know if a certain site requires such without having to 'knock on every door' manually? Like for instance at Fermilab where this is required. I only know it is required because I talked to Burt. Otherwise I would have no idea.
>>> The requirement for voms proxies is explicitly published in the
>>> FermiGrid policy document:
>>>    http://fermigrid.fnal.gov/policy.html
>>> Direct quote from the above document:
>>>    VOs and VO members that desire to Fermilab grid resources must initialize
>>>    their credentials using:
>>>        * $VDT_LOCATION/voms/bin/voms-proxy-init
>>>    Those VOs and VO members that fail to use voms-proxy-init may be blocked
>>>    from accessing Fermilab grid resources.
>>> -Keith.
>>>> Thanks,
>>>> Robert
>>>> Iwona Sakrejda wrote:
>>>>> But even not all the sites that run GUMS servers requirer VOMS proxy.
>>>>> So I'd say - if a proxy is rejected by a site, is the error message clear? I never tried....
>>>>> Also the user should check with the VO. If a vo is utilizing functionality that comes with
>>>>> a VOMS proxy, it will be presumably educating its users about available roles and such, no?
>>>>> Always asking for a VOMS proxy is safer. If no VOMS server available - it will be reduced to
>>>>> a regular proxy. If a site is using map files, the extra stuff will be ignored and the proxy will
>>>>> work anyway.
>>>>> Isn't it so?
>>>>> Iwona
>>>>> On Wed, Jun 16, 2010 at 2:57 PM, Robert Engel <engel_r at ligo.caltech.edu <mailto:engel_r at ligo.caltech.edu>> wrote:
>>>>>    Steven,
>>>>>    ? Do you know how a user could find out what RSV probes are
>>>>>    running on any given site? I tried to find this in myOSG, but
>>>>>    nothing turned up.
>>>>>    Thanks,
>>>>>    Robert
>>>>>    Steven Timm wrote:
>>>>>        The answer is not always a clear yes or no. ?If a site copies
>>>>>        the OSG GUMS template and runs GUMS then they will end up
>>>>>        requiring voms proxies for about half of the VO's and not
>>>>>        for the other half.
>>>>>        You could indirectly find out by which RSV probes any given site
>>>>>        is running, GUMS sites run different RSV probes than grid-mapfile
>>>>>        sites do. ?by default all grid-mapfile sites do not require
>>>>>        any VOMS proxy.
>>>>>        FermiGrid is the only site I know of that requires VOMS proxy for
>>>>>        everyone and even we have a way to make exceptions if necessary.
>>>>>        Steve
>>>>>        On Wed, 16 Jun 2010, Robert Engel wrote:
>>>>>            Hello,
>>>>>            ?I am writing documentation for end users. I would like to
>>>>>            write how a user can find out if a site accepts a Grid
>>>>>            Proxy or requires a VOMS Proxy. Can that information be
>>>>>            found in myOSG?
>>>>>            Thanks,
>>>>>            Robert
>>>> Attachment converted: Macintosh HD:engel_r 18.vcf (TEXT/ttxt) (0040AFA0)
>> <engel_r.vcf>
