[Swift-devel] Re: Site Tester
    Mihael Hategan
    hategan at mcs.anl.gov
    Fri Jun 11 19:23:24 CDT 2010
Also, I'm using the following for I2U2:
https://trac.ci.uchicago.edu/i2u2/browser/branches/1.3/common/src/jsp/monitor/monitor.k
https://trac.ci.uchicago.edu/i2u2/browser/branches/1.3/common/src/jsp/monitor/tests.k
It generates machine friendly output which is used by:
http://www18.i2u2.org/elab/cosmic/monitor/
(you should probably not try that with I.E.)
Mihael
On Fri, 2010-06-11 at 13:19 -0500, Mihael Hategan wrote:
> On Fri, 2010-06-11 at 12:56 -0500, Arjun Comar wrote:
> > Hey Mihael,
> > You mentioned that you knew the location of a site tester. Is that
> > already in svn? If so, what's it under?
> There's a basic thing in bin/checksites.k written in Karajan. It goes
> through a sites file, tries some basic stuff and handles timeouts.
> But you may want to write something in Java or so.
> Mihael
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
