[Swift-devel] TC File Generator
    Ben Clifford
    benc at hawaga.org.uk
    Thu Jun 10 02:28:03 CDT 2010
often the tc.data file is a mostly needless hassle, such as when pointing
at stuff that is on the path and is installed on every site that you will
use.
but it does contain some information that cannot be automatically
discovered - for example I want to use version X of software package A on
one site, and version Y of software package A on another site, and those
packages are not in the default path.
tc.data is possibly (probably?) not the easiest way to express that (for
users, rather than for the software to use to lookup).
for example, you could say "mogrify and convert are in ImageMagick. and to
use ImageMagick first you need to source setup.sh in its etc directory. On
site A, imagemagick is at /opt/ImageMagick/1.0/ and on site B it is in
/usr and on site C it is not present".".
without needing to require the end user to multiple out the package
description x executable lines in tc.data
then you end up with something that looks a bit more like a multisite
softenv, describing packages rather than individual executables.
-- http://www.hawaga.org.uk/ben/
