[Swift-devel] coaster worker syntax errors
    Justin M Wozniak
    wozniak at mcs.anl.gov
    Fri Jun  4 13:46:12 CDT 2010
This should be fixed in the latest CoG.
On Wed, 2 Jun 2010, Justin M Wozniak wrote:
> I came across the same issues and have some preliminary fixes- more to
> come...
> On Mon, 24 May 2010, Allan Espinosa wrote:
>> I would like to use trunk to be able to use the CDM features when
>> running on OSG resources.  In the meantime i'll tryout cog-stable and
>> swift-trunk.
>> swift-r3288 cog-r2752
>> RunID: 20100524-1955-h9to7jt4
>> Progress:
>> Progress:  Selecting site:1  Initializing site shared directory:1  Stage
>> in:1
>> Progress:  Submitting:2  Submitted:1
>> Progress:  Submitted:2  Active:1
>> Failed to transfer wrapper log from
>> 066-many-20100524-1955-h9to7jt4/info/n on TERAPORT
>> Progress:  Submitted:2  Failed:1
>> Execution failed:
>>        Exception in sleep:
>> Arguments: [300]
>> Host: TERAPORT
>> Directory: 066-many-20100524-1955-h9to7jt4/jobs/n/sleep-nivmsfsj
>> stderr.txt:
>> stdout.txt:
>> Caused by:
>>        Task failed: 0524-550712-000000 Block task ended prematurely
>> Use of uninitialized value in concatenation (.) or string at
>> /home/osgvo/engage/.globus/coasters/cscript2747241842007159708.pl line
>> 192.
>> Failed to connect: Illegal seek at
>> 169.
>> Cleaning up...
>> Shutting down service at https://128.135.125.118:57300
>> Got channel MetaChannel: 988943951 -> GSSSChannel-01884231335(1)
>> + Done
Justin M Wozniak
