[Swift-devel] Swift shell script and JAVA_HOME
    David Kelly
    dk0966 at cs.ship.edu
    Tue Jul 20 10:27:30 CDT 2010
On Tue, Jul 20, 2010 at 9:43 AM, Michael Wilde <wilde at mcs.anl.gov> wrote:
In my .soft i have +java_sub before @default in .soft. That seems to work on
> login.ci. Can you try that?
> Changing the ordering fixed it for me as well. Thanks.
> What error were you getting?
> Perhaps check if other *JAVA* env vars are still pointing to the wrong
> Java, eg:
> login$ env | grep -i java
> JRE_HOME=/soft/java-1.5.0_06-sun-r1/jre
> MATLAB_JAVA=/soft/matlab-7.7-r1/java
> JAVA_BINDIR=/soft/java-1.5.0_06-sun-r1/bin
> JAVA_HOME=/soft/java-1.5.0_06-sun-r1
> SDK_HOME=/soft/java-1.5.0_06-sun-r1
> JDK_HOME=/soft/java-1.5.0_06-sun-r1
> JAVA_ROOT=/soft/java-1.5.0_06-sun-r1
> and make sure that CLASSPATH is *not* set.
If I have @default first followed +java_sun, even if all of the JAVA
variables correctly pointing to sun java it will use gcj. I think this is
due to the ordering of directories in $PATH. Having users adjust their PATH
with the location of sun java ahead of directories like /usr/bin is probably
the solution.
Here are the errors I was getting:
$ swift manyparam.swift
Warning: -Xmx256M not understood. Ignoring.
log4j:ERROR Error occured while converting date.
java.lang.IllegalArgumentException: Illegal pattern character
   at java.text.SimpleDateFormat.format(java.util.Date,
java.lang.StringBuffer, java.text.FieldPosition) (/usr/lib/libgcj.so.5.0.0)
   at java.text.DateFormat.format(java.util.Date) (/usr/lib/libgcj.so.5.0.0)
   at
org.apache.log4j.helpers.PatternParser$DatePatternConverter.convert(org.apache.log4j.spi.LoggingEvent)
(Unknown Source)
   at
org.apache.log4j.helpers.PatternConverter.format(java.lang.StringBuffer,
org.apache.log4j.spi.LoggingEvent) (Unknown Source)
   at
org.apache.log4j.PatternLayout.format(org.apache.log4j.spi.LoggingEvent)
(Unknown Source)
   at
org.apache.log4j.WriterAppender.subAppend(org.apache.log4j.spi.LoggingEvent)
(Unknown Source)
   at
org.apache.log4j.WriterAppender.append(org.apache.log4j.spi.LoggingEvent)
(Unknown Source)
   at
org.apache.log4j.AppenderSkeleton.doAppend(org.apache.log4j.spi.LoggingEvent)
(Unknown Source)
   at
org.apache.log4j.helpers.AppenderAttachableImpl.appendLoopOnAppenders(org.apache.log4j.spi.LoggingEvent)
(Unknown Source)
   at
org.apache.log4j.Category.callAppenders(org.apache.log4j.spi.LoggingEvent)
(Unknown Source)
   at org.apache.log4j.Category.forcedLog(java.lang.String,
org.apache.log4j.Priority, java.lang.Object, java.lang.Throwable) (Unknown
Source)
   at org.apache.log4j.Category.debug(java.lang.Object) (Unknown Source)
   at org.griphyn.vdl.karajan.Loader.main(java.lang.String[]) (Unknown
Source)
   at
(Unknown Source)
   at
   at
(Unknown Source)
   at
(Unknown Source)
   at
(Unknown Source)
   at
(Unknown Source)
   at
(Unknown Source)
   at
(Unknown Source)
Source)
Source)
   at
(Unknown Source)
   at
   at
(Unknown Source)
   at
(Unknown Source)
   at
(Unknown Source)
   at
(Unknown Source)
   at
(Unknown Source)
   at
(Unknown Source)
Source)
   at org.griphyn.vdl.karajan.Loader.compile(java.lang.String) (Unknown
Source)
Source)
   at
(Unknown Source)
   at
   at
(Unknown Source)
   at
(Unknown Source)
   at
(Unknown Source)
   at
(Unknown Source)
   at
(Unknown Source)
   at
(Unknown Source)
Source)
Source)
Source)
   at
(Unknown Source)
   at
   at
(Unknown Source)
   at
(Unknown Source)
   at
(Unknown Source)
   at
(Unknown Source)
   at
(Unknown Source)
   at
(Unknown Source)
Source)
Source)
Source)
Exception in thread "main" java.lang.NullPointerException
*** Got java.lang.NullPointerException while trying to print stack trace.
David
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20100720/b752141f/attachment.html>
