[Swift-devel] swift config files for running on multiple multicore	machines
    wilde at mcs.anl.gov
    Mon Jul 12 13:50:25 CDT 2010
attached.
You need to set up an ssh key, and put its passphrase in ~/.ssh/auth.defaults.
make sure that auth.defaults is mode 600 (not readable by others)
You also need to create a GSI proxy on the submit host, and make sure that X509_CERT_DIR on the target hosts is set to a valid CA certificate dir:
export X509_CERT_DIR=/home/wilde/TRUSTEDCA
export X509_CADIR=/home/wilde/TRUSTEDCA
- Mike
Type: application/xml
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20100712/611a4485/attachment.xml>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20100712/611a4485/attachment.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20100712/611a4485/attachment-0001.obj>
