[Swift-devel] Swift hanging on array close?
    Michael Wilde
    wilde at mcs.anl.gov
    Fri Jul  9 15:18:09 CDT 2010
In the following script, two nested foreach stmts fill a sparse array. @filenames(array) is then passed to an ext mapper.
This seems to hang: the ext mapper is never called.
This code in on the mcs net in ~wilde/swift/lab/sgflow.
Mihael and/or Justin, can you take a look? The FL group needs this for a tutorial next week (and has lots more to do, so a quick fix or workaround this afternoon would be very helpful)
Mike
type file;
# <bus> is integer between 1 and 30
# <power> is in megawatts
app (file o) sgflow (int bus, int power)
  sgflow bus power stdout=@o;
app (file o) mkgraph (file i)
  awk "-f" "/home/turam/tmp/mkgraph.awk" @filename(i) stdout=@o;
app (file o) mktable (file i)
  awk "-f" "/home/turam/tmp/SGsplitter.awk" stdin=@i;
file ofiles[] <ext;exec="ofiles.map">;
string nbus = @arg("nbus","1");
string nplevel = @arg("nplevel", "2");
foreach bus in [1:@toint(nbus)] {
  foreach plevel in [1:@toint(nplevel)] {
    # file o<single_file_mapper; file=@strcat("out.","bus.",bus,".pow.",plevel)>;
    ofiles[bus*@toint(nplevel)+plevel] = sgflow(bus,plevel);
file i <ext;exec="mktableinput.sh",o="out.csv",i=@filenames(ofiles)>;
# ^^^^ hangs here - mktableinput.sh is never called.
# trace(@filenames(ofiles)) also hangs.
file otable <"otable.txt">;
otable = mktable(i);
ofiles.map is hardcoded to return ofile.3 and ofile.4 - this works, and those files get the expected output.
Michael Wilde
Computation Institute, University of Chicago
Mathematics and Computer Science Division
Argonne National Laboratory
