[Swift-devel] manual coasters
    Justin M Wozniak
    wozniak at mcs.anl.gov
    Fri Jul  2 14:40:23 CDT 2010
On Wed, 30 Jun 2010, Mihael Hategan wrote:
> Manual coasters are in trunk. I did some limited testing on localhost.
I'm getting a problem where the original callback URI is null.  Is it
possible that it is due to this change?
Triggered with null pointer at Settings.java:239
Caused by: java.lang.NullPointerException
 	at
org.globus.cog.abstraction.coaster.service.job.manager.Settings.setInternalHostname(Settings.java:239)
 	... 11 more
Failed to set configuration
java.lang.IllegalArgumentException: Cannot set: internalHostname to:
172.17.5.144
 	at
org.globus.cog.abstraction.coaster.service.job.manager.Settings.set(Settings.java:437)
 	at
org.globus.cog.abstraction.coaster.service.ServiceConfigurationHandler.requestComplete(ServiceConfigurationHandler.java:39)
 	at
org.globus.cog.karajan.workflow.service.handlers.RequestHandler.receiveCompleted(RequestHandler.java:84)
 	at
org.globus.cog.karajan.workflow.service.channels.AbstractKarajanChannel.handleRequest(AbstractKarajanChannel.java:381)
 	at
org.globus.cog.karajan.workflow.service.channels.AbstractPipedChannel.actualSend(AbstractPipedChannel.java:79)
 	at
org.globus.cog.karajan.workflow.service.channels.AbstractPipedChannel$Sender.run(AbstractPipedChannel.java:108)
Justin M Wozniak
