[Swift-devel] manual coasters
    Allan Espinosa
    aespinosa at cs.uchicago.edu
    Thu Jul  1 17:21:35 CDT 2010
So for the pool entry below, where is the serviceURL?  the submit host
will issue a pbs request for a service host?
-Allan
2010/7/1  <wilde at mcs.anl.gov>:
> Very cool - thanks, Mihael!
> For the sites entry, do we still use the current format to indicate where the server should start?
> Eg:
>  <pool handle="coasterpool01">
>    <execution provider="coaster" url="none" jobManager="pbs"/>
>    <profile namespace="globus"> key="workerManager">passive</profile>
>    <profile namespace="globus" key="queue">fast</profile>
>    <profile namespace="karajan" key="initialScore">10000</profile>
>    <profile namespace="karajan" key="jobThrottle">.07</profile>
>    <gridftp  url="local://localhost" />
>    <workdirectory >/home/wilde/swiftwork</workdirectory>
>  </pool>
> Is the full range of provider options available to start the server in passive mode?
> Will throttling settings be honored?
> Can we start multiple coaster servers in different places?
> - Mike
> ----- "Mihael Hategan" <hategan at mcs.anl.gov> wrote:
>> Manual coasters are in trunk. I did some limited testing on
>> localhost.
>> The basic idea is that you say <profile namespace="globus"
>> key="workerManager">passive</profile> in sites.xml. Other than that
>> you
>> may want to set workersPerNode, but the other options are useless.
>> Then, when swift starts the coaster service, it will print the URL of
>> that on stderr.
>> You carefully dig for worker.pl and then launch it in whatever way
>> you
>> like:
>> worker.pl <ServiceURL> <blockid> <logdir>
>> The blockid can be whatever you want, but it can be used to group
>> workers in the traditional blocks. The logdir is where you want the
>> worker logs to go. They are all mandatory.
>> When workers connect to the service, the service should start
>> shipping
>> jobs to them. When the service is shut down, it will also try to shut
>> down the workers (they are useless anyway at that point), but it
>> cannot
>> control the LRM jobs, so it may fail to do so (or rather said, it is
>> more likely to fail to do so).
>> Mihael
