[Swift-devel] Problem with iterate
Ioan Raicu iraicu at cs.uchicago.edu
Fri Feb 19 11:50:37 CST 2010
I think we are on the same page, that if you cannot resolve the
dependencies, things just fall apart. The part I don't get, is why would
you get a deadlock in this situation (which is where this whole
discussion started from), as opposed to an error detecting that the DAG
cannot be constructed? It seems that at the time of DAG construction (I
assume this is the SwiftScript compilation stage), any failure to add
nodes to the DAG due to unresolved dependencies should return an error
and halt, rather than execute until the deadlock happens.
Ioan Raicu, Ph.D.
NSF/CRA Computing Innovation Fellow
Center for Ultra-scale Computing and Information Security (CUCIS)
Department of Electrical Engineering and Computer Science
Northwestern University
2145 Sheridan Rd, Tech M384
Evanston, IL 60208-3118
Cel:   1-847-722-0876
Tel:   1-847-491-8163
Email: iraicu at eecs.northwestern.edu
Web:   http://www.eecs.northwestern.edu/~iraicu/
       https://wiki.cucis.eecs.northwestern.edu/
Mihael Hategan wrote:
> On Fri, 2010-02-19 at 11:36 -0600, Ioan Raicu wrote:
>> But doesn't the single assignment criteria prevent loops from
>> happening in the dependency graph?
> No. What you are probably thinking is that if each node in a graph would
> represent an assignment then the loop would only be executed once after
> which, due to single assignment, there would be an error.
> However the loop is not executed at all, because there is no way to
> satisfy the dependencies of both nodes (x depends on y and y depends on
> x).
Ioan Raicu, Ph.D.
Cel:   1-847-722-0876
Tel:   1-847-491-8163
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20100219/d8b2b645/attachment.html>
