[Swift-devel] Problem with iterate
    Mihael Hategan
    hategan at mcs.anl.gov
    Thu Feb 18 16:07:29 CST 2010
On Thu, 2010-02-18 at 17:08 +0000, Ben Clifford wrote:
> > I'm unsure. I have a feeling that static dealdock detection is
> > undecidable in swift. I need to think some more about that.
> I think doing it statically (i.e. at compile time) is equivalent to
> executing the code (including external apps) - I think there's probably a
> straightforward example where something depends on an integer read from an
> externally executed app which then influences an if statement that decides
> which of two different arrays is being written to; or something like that.
Right. So termination is undecidable by virtue of it being a turing
complete language. What I'm unsure is whether deadlocks follow as a
consequence of that. They are a different beast.
We can probably start with simpler things. The following deadlocks with
the current swift:
a = cat(b);
b = cat(a);
So it seems that loops in the graph will create a deadlock and detecting
loops requires knowing the graph. We can probably detect the static
parts and we may be able to handle alternatives by issuing warnings of
the "branch 1 in that 'if' combined with branch 2 in that other 'if'
leads to a deadlock" sort.
Arrays may be a bit tougher.
