[Swift-devel] [Bug 239] New: Java 1.5 compatibility issue - @Override
bugzilla-daemon at mcs.anl.gov
Wed Dec 29 20:46:58 CST 2010
https://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=239
Summary: Java 1.5 compatibility issue - @Override
Product: Swift
Version: unspecified
Platform: PC
OS/Version: Linux
Status: NEW
Severity: normal
Priority: P2
Component: General
AssignedTo: hategan at mcs.anl.gov
ReportedBy: dk0966 at cs.ship.edu
When trying to build swift with Java 1.5, I receive errors related to the use
of @Override.
In Java 1.5 you can only use the @Override annotation when overriding methods
of a class. If the method is defined in an interface rather than a superclass,
a compilation error will occur. (1.6 allows @Override for both classes and
interfaces)
I ran into this when trying to build swift on sisboombah. Patch attached.
java version "1.5.0_14"
Java(TM) 2 Runtime Environment, Standard Edition (build 1.5.0_14-b03)
Java HotSpot(TM) 64-Bit Server VM (build 1.5.0_14-b03, mixed mode)
Ant output
compile:
[echo] [util]: COMPILE
[mkdir] Created dir: /home/dk0966/cog/modules/util/build
[javac] Compiling 53 source files to /home/dk0966/cog/modules/util/build
[javac]
/home/dk0966/cog/modules/util/src/org/globus/cog/util/CopyOnWriteArrayList.java:71:
method does not override a method from its superclass
[javac] @Override
[javac] ^
[javac]
/home/dk0966/cog/modules/util/src/org/globus/cog/util/CopyOnWriteArrayList.java:105:
[javac] @Override
[javac] ^
[javac]
/home/dk0966/cog/modules/util/src/org/globus/cog/util/CopyOnWriteArrayList.java:144:
[javac] @Override
[javac] ^
[javac]
/home/dk0966/cog/modules/util/src/org/globus/cog/util/CopyOnWriteArrayList.java:227:
[javac] @Override
[javac] ^
[javac]
/home/dk0966/cog/modules/util/src/org/globus/cog/util/CopyOnWriteArrayList.java:232:
[javac] @Override
[javac] ^
[javac]
/home/dk0966/cog/modules/util/src/org/globus/cog/util/CopyOnWriteArrayList.java:237:
[javac] @Override
[javac] ^
[javac]
/home/dk0966/cog/modules/util/src/org/globus/cog/util/CopyOnWriteArrayList.java:242:
[javac] @Override
[javac] ^
[javac]
/home/dk0966/cog/modules/util/src/org/globus/cog/util/CopyOnWriteArrayList.java:247:
[javac] @Override
[javac] ^
[javac]
/home/dk0966/cog/modules/util/src/org/globus/cog/util/CopyOnWriteArrayList.java:252:
[javac] @Override
[javac] ^
[javac]
/home/dk0966/cog/modules/util/src/org/globus/cog/util/CopyOnWriteArrayList.java:257:
[javac] @Override
[javac] ^
[javac] Note: Some input files use or override a deprecated API.
[javac] Note: Recompile with -Xlint:deprecation for details.
[javac] Note: Some input files use unchecked or unsafe operations.
[javac] Note: Recompile with -Xlint:unchecked for details.
[javac] 10 errors
Configure bugmail: https://bugzilla.mcs.anl.gov/swift/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are watching the assignee of the bug.
