[Swift-devel] Re: Running the GO Swift prototype
Michael Wilde
wilde at mcs.anl.gov
Wed Dec 15 19:38:40 CST 2010
Hmmm - looking briefly at the Karajan library, I see elements that will *perhaps* let us write out request files. We'd need to read notifications in in units of a file at a time, and parse them. Somewhat primitive, but maybe workable for prototyping.
Writing a regular provider is starting to look like a better idea.
- Mike
----- Original Message -----
> One possibility for scaling:
> - instead of calling task:execute(external.sh), have dostagein() put
> the request into the "ready/" queue/dir, just like external.sh does
> now, but direct from Karajan (ie, dont fork a process and shell).
> - then wait on a future in a map of futures, with the map key being
> the request id.
> - a listener reads the done/ queue periodically, posting the futures
> of the completed requests based on keys that remain associated with
> the requests in the queue
> This approach does not replace a true data provider: its still just a
> prototype to learn more about how to do staging efficiently using
> external interfaces.
> But its possible that if you know Karajan well the above logic is
> pretty easy, while writing a real data provider is more like a week of
> work or more, just to learn the mechanics. (And I think working out
> the interface logic to the external tool or service, as above, will
> help in building the provider).
> - Mike
> > Hi Allan,
> > This is at least partial good news, and nice progress.
> > First step we can try on scaling (maybe easy, maybe not) is to cut
> > down on external processes. I'll take a quick look and see if I can
> > spot another strategy.
> > The obvious strategy would be to bite the bullet and move to a true
> > provider, that can keep a huge number of requests pending without
> > consuming heavy resources.
> > I'm fearful that external.sh needs to be synchronous, but maybe we
> > can
> > use a slightly different interface to separate the requests from the
> > notifications.
> > - Mike
> > > Hi Mike,
> > > I got the basic functionality working from your sample external.sh
> > > scripts. I was able to synthesize a workload of 200 transfers.
> > > I'll
> > > send you and raj about that in another email.
> > > The basic scripts starts to break at 3000 transfers. I set my
> > > number
> > > of files to 10k and foreach.maxthread to 3000 . I guess at this
> > > point, external.sh already create too much files at a time for the
> > > ready queue to handle. The number of processes forked is probably
> > > too
> > > much as well. communicado is already crawling at this point. Even
> > > though Swift already reported 3000 files staged in. The logs in
> > > external.sh only reported 758 transfers initiated to globus
> > > online.
> > > A CDM external handler will probably blow-up in general as it will
> > > fork a process / shellscript for each transfer. If foreach is set
> > > to
> > > 10000, we can't scale.
> > > I guess a more scalable solution for swift is to make a native
> > > call
> > > (karajan/java) to a queueing service (something like Stork in
> > > condor)
> > > for data transfer.
> > > -Allan
> > > 2010/12/13 Michael Wilde <wilde at mcs.anl.gov>:
> > > > Allan, the code is on PADS login1 under /scratch and seems to
> > > > work.
> > > > You will need to look into the swift/src/trunk.gomods src tree
> > > > to
> > > > see what I changed in there. Some but perhaps not all the diffs
> > > > in
> > > > that tree are for supporting globus online.
> > > > Let me know if you can replicate the example test below.
> > > > Justin, it would be good if we can integrate the mods for this
> > > > into
> > > > trunk in some non-invasive way as way to share these tests, even
> > > > if
> > > > we do it as a separate vdl-int.GO.k that the user/experimenter
> > > > needs
> > > > to manually copy to vdl-int.k
> > > > Or I guess we could put them in an experimental branch?
> > > > - Mike
> > > > 1 ) gorunner.sh >& gorunner.out
> > > > 2 )
> > > > PATH=/scratch/local/wilde/swift/src/trunk.gomods/cog/modules/swift/dist/swift-svn/bin:$PATH
> > > > 3 ) swift -config cf -tc.file tc.data -sites.file sites.xml
> > > > -cdm.file fs.ftponly gcat2.swift
> > > > Thats it.
> > > > In gorunner.out, should see:
> > > > ./gorunner.sh: joblist is empty
> > > > ./gorunner.sh: joblist is:
> > > > cp-yuptfz2k.job.in
> > > > ./gorunner.sh: started transfer task
> > > > 4dfe903e-06f7-11e0-aa30-1231350018b1
> > > > /home/wilde/swift/lab/go/gowaiter.sh: waiting on
> > > > 4dfe903e-06f7-11e0-aa30-1231350018b1 has completed
> > > > /home/wilde/swift/lab/go/gowaiter.sh: marked cp-yuptfz2k.job.in
> > > > transferred
> > > > On swift stdout/err should see:
> > > > login1$ swift -config cf -tc.file tc.data -sites.file sites.xml
> > > > CDM file: fs.ftponly
> > > > Swift svn swift-r3707 (swift modified locally) cog-r2932 (cog
> > > > modified locally)
> > > > RunID: 20101213-1426-dff3my97
> > > > Progress:
> > > > /home/wilde/swift/lab/go/external.sh: running in
> > > > Progress: Submitting:1
> > > > in /home/wilde/swift/lab/go/cp.sh:
> > > > wd=/home/wilde/swift/lab/go/work/gcat2-20101213-1426-dff3my97/jobs/y/cp-yuptfz2k
> > > > arg1=etc/group arg2=output/plainoutput.txt
> > > > in /home/wilde/swift/lab/go/cp.sh: rc=0
> > > > Progress: Checking status:1
> > > > Final status: Finished successfully:1
> > > > login1$
> > > > Thats it.
> > Michael Wilde
> > Computation Institute, University of Chicago
> > Mathematics and Computer Science Division
> > Argonne National Laboratory
> Michael Wilde
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
Michael Wilde
