[Swift-devel] Using multicore servers as Swift pools
Michael Wilde
wilde at mcs.anl.gov
Mon Dec 13 12:01:49 CST 2010
Luiz,
An example of the config files you will need in order to use the 10 8-core 64-but MCS compute servers as Swift pools is on the CI net under /home/wilde/swift/lab/{coasters.xml,auth.defaults.sample}
The servers (10 x 64 bit and 3 x 32 bit) are listed at:
http://wiki.mcs.anl.gov/IT/index.php/General_MCS_Questions#computeservers
Since these machines are behind a firewall, you can use the ~/.ssh/config example below (adapted as needed) to make them accessible as if they permitted direct login. You login to login.mcs.anl.gov using your local ssh key, and then ssh ports are forwarded to each of the target machines that you want on the MCS network. The technique is explained at:
http://articles.techrepublic.com.com/5100-10878_11-6155832.html
This is one of the configurations we should test with new test scripts for Swift 0.91
Ive pasted the files below as well.
- Mike
=== auth.defaults.sample ===
xlogin1.pads.ci.uchicago.edu.type=password
xlogin1.pads.ci.uchicago.edu.username=wilde
login.pads.ci.uchicago.edu.type=key
login.pads.ci.uchicago.edu.username=wilde
login.pads.ci.uchicago.edu.key=/home/wilde/.ssh/swift_rsa
login.pads.ci.uchicago.edu.passphrase=mypassphrasegoeshere
login.mcs.anl.gov.type=key
login.mcs.anl.gov.username=wilde
login.mcs.anl.gov.key=/home/wilde/.ssh/swift_rsa
login.mcs.anl.gov.passphrase=mypassphrasegoeshere
=== ~/.ssh/config set up for forwarding one compute server, "crush"
Host *
ServerAliveInterval 15
#ControlMaster auto
#ControlPath ~/.ssh/ssh-connections/%r@%h:%p
# COMPUTEHOSTS='crush thwomp stomp crank steamroller grind churn trounce thrash vanquish'
Host mcs login.mcs.anl.gov
Hostname login.mcs.anl.gov
ForwardAgent yes
ForwardX11 no
LocalForward 19001 140.221.8.62:22
Host crush thwomp stomp crank steamroller grind churn trounce thrash vanquish
ForwardAgent yes
ForwardX11 no
Hostname localhost
NoHostAuthenticationForLocalhost yes
Host crush
Port 19001
=== coasters.xml ===
<config>
<pool handle="crush">
<execution provider="coaster" url="crush.mcs.anl.gov" jobmanager="ssh:local"/>
<profile namespace="globus" key="workersPerNode">8</profile>
<profile namespace="globus" key="maxTime">3500</profile>
<profile namespace="globus" key="slots">1</profile>
<profile namespace="globus" key="nodeGranularity">1</profile>
<profile namespace="globus" key="maxNodes">1</profile>
<filesystem provider="local" url="none" />
<profile key="jobThrottle" namespace="karajan">.07</profile>
<profile namespace="karajan" key="initialScore">10000</profile>
<workdirectory>/home/wilde/swiftwork/crush</workdirectory>
</pool>
<pool handle="thwomp">
<execution provider="coaster" url="thwomp.mcs.anl.gov" jobmanager="ssh:local"/>
<profile key="jobThrottle" namespace="karajan">.31</profile>
<workdirectory>/home/wilde/swiftwork/thwomp</workdirectory>
</pool>
...etc for the rest of the 10 compute servers...
- Mike
