[Swift-devel] Re: Does hookClass sites tag affect concurrency/throttling?
Justin M Wozniak wozniak at mcs.anl.gov
Sun Dec 5 22:24:43 CST 2010
This is a callback that is triggered by coasters when a Block is
allocated.  This result is a real surprise, I'll check this out right
away.
On Sun, 5 Dec 2010, Michael Wilde wrote:
> Justin, what does this line in sites.xml do on the BG/P?
>    <profile namespace="globus"  key="hookClass">org.globus.swift.data.policy.AllocationHook</profile>
> I think I got that from one of your examples for BG/P use; when I use
> it, I seem to get throttled to about 20 active jobs max.  When I take it
> off, I seem to be able to utilize all CPUs in a pset (256 cores in my
> last test).
> My full pool element which seems to be limiting me to about 20 active is
> this (despite the fact that the throttle should let 276 jobs run at
> once):
>  <pool handle="surveyor-pecos-2">
>    <filesystem provider="local" />
>    <execution provider="coaster-persistent" url="http://localhost:1985" jobmanager=""/>
>    <profile namespace="globus" key="workerManager">passive</profile>
>    <!-- profile namespace="globus"  key="internalHostname">172.17.3.16</profile> -->
>    <profile namespace="globus"  key="project">HTCScienceApps</profile>
>    <profile namespace="globus"  key="queue">default</profile>
>    <profile namespace="globus"  key="kernelprofile">zeptoos</profile>
>    <profile namespace="globus"  key="alcfbgpnat">true</profile>
>    <profile namespace="karajan" key="jobthrottle">2.75</profile>
>    <profile namespace="karajan" key="initialScore">10000</profile>
>    <profile namespace="globus"  key="workersPerNode">4</profile>
>    <profile namespace="globus"  key="slots">1</profile>
>    <profile namespace="globus"  key="maxTime">3600</profile>
>    <profile namespace="globus"  key="nodeGranularity">64</profile>
>    <profile namespace="globus"  key="maxNodes">64</profile>
>    <scratch>/dev/shm</scratch>
>    <workdirectory>$rundir</workdirectory>
>  </pool>
> When I use the following pool element, I get the full expected concurrency:
>  <pool handle="surveyor-pecos">
>    <profile key="jobThrottle" namespace="karajan">3.00</profile>
>    <filesystem provider="local" url="none" />
>  </pool>
> While I am not *sure* its the hookClass tag thats causing the throttling, but its my primary suspect. I will try to confirm, but Im still curious what this tag does.
> Thanks,
> Mike
Justin M Wozniak
