[Swift-devel] Issues to resolve for new coaster modes
wilde at mcs.anl.gov wilde at mcs.anl.gov
Tue Aug 31 10:49:44 CDT 2010
Here's the issues that I am aware of so far. Many of these need more discussion and/or debug/reproduction info.
- -nosec doesnt seem to work on coaster-service command
  alternative: a wrapper script automatically installs an insecure SimpleCAbased proxy and necessary CA certs. We're using wrappers anyways, to start manual workers.
- need -passive option on coaster-service command (for now, can run a dummy swift job to force coaster service into passive mode?)
- file protocol for coaster provider staging seems broken
- -port option on coaster-service command seems to print confusing messages and its unclear how the specified port vs the default port is being used (try to probe with netstat).
- its unclear how to specify URIs for the service in sites.xml, in particular http: vs https: protocol and ports. Both are printed by the service: which to use?
- still need an easy way to enable users to use remote coasters without an X509 certificate
- in initial tests, the persistent coaster service seemed to work for a few swift commands, then hung or stopped responding. Workers timed out? Need to reproduce this and check logs.
- in initial tests, both David and Mike have seen coaster service go into a rapid heartbeat (~ 1 per sec) mode.
- distantly related: verify if ssh to a set of hosts that use the same ssh key only request the passphrase once from the user. If not, can that caching be implemented to avoid multiple passphrase entry?
David, do you have additional issues, or clarifications/details on any of these?
Mihael, and suggestions for approaches on any of these that are low hanging fruit which people other than you can work on?
