[Swift-devel] Provider staging is failing
    wilde at mcs.anl.gov
    Mon Aug 30 20:02:59 CDT 2010
OK, I see now that it is honoring the workdirectory tag. (I thought that was not used with provider staging, but seems that it is).
WHen mkdir was failing I was getting an  error code 524; now Im getting an error code 520 - seems to be failing now in the actual transfer of swiftwrap.
worker log is pasted below.
- Mike
com$ cat worker-0830-560709-000000.log
1283216169.574 INFO  - 0830-560709-000000 Logging started: Mon Aug 30 19:56:09 2010
1283216169.576 INFO  - Running on node communicado.ci.uchicago.edu
1283216169.576 DEBUG - uri=http://128.135.125.17:50001
1283216169.576 DEBUG - scheme=http
1283216169.576 DEBUG - host=128.135.125.17
1283216169.576 DEBUG - port=50001
1283216169.576 DEBUG - blockid=0830-560709-000000
1283216169.576 INFO  - Connecting (0)...
1283216169.576 DEBUG - Trying 128.135.125.17:50001...
1283216169.578 INFO  - Connected
1283216169.578 DEBUG - Replies: {}
1283216169.578 DEBUG - OUT: len=8, tag=0, flags=0
1283216169.578 DEBUG - OUT: len=18, tag=0, flags=0
1283216169.578 DEBUG - OUT: len=0, tag=0, flags=2
1283216169.578 DEBUG - done sending frags for 0
1283216169.623 DEBUG - Fin flag set
1283216169.624 INFO  000000 Registration successful. ID=000000
1283216169.624 DEBUG 000000 New request (1)
1283216169.624 DEBUG 000000 Fin flag set
1283216169.624 DEBUG 000000 Processing request
1283216169.625 DEBUG 000000 Cmd is SUBMITJOB
1283216169.625 INFO  000000 1283216169479 Job info received (tag=1)
1283216169.625 DEBUG 000000 1283216169479 Job check ok (dir: /home/wilde/swiftwork/catsn-20100830-1956-z61dqk05-d-cat-duz412yj)
1283216169.625 INFO  000000 1283216169479 Sending submit reply (tag=1)
1283216169.625 DEBUG 000000 OUT: len=2, tag=1, flags=3
1283216169.625 DEBUG 000000 done sending frags for 1
1283216169.625 INFO  000000 1283216169479 Submit reply sent (tag=1)
1283216169.625 DEBUG 000000 Replies: {}
1283216169.625 DEBUG 000000 OUT: len=9, tag=1, flags=0
1283216169.625 DEBUG 000000 OUT: len=13, tag=1, flags=0
1283216169.625 DEBUG 000000 OUT: len=2, tag=1, flags=0
1283216169.625 DEBUG 000000 OUT: len=1, tag=1, flags=0
1283216169.625 DEBUG 000000 OUT: len=15, tag=1, flags=2
1283216169.626 DEBUG 000000 done sending frags for 1
1283216169.626 DEBUG 000000 1283216169479 Staging in file://localhost//home/wilde/swift/rev/trunk/bin/../libexec/_swiftwrap.staging
1283216169.626 DEBUG 000000 1283216169479 src: file://localhost//home/wilde/swift/rev/trunk/bin/../libexec/_swiftwrap.staging, protocol: file, path: localhost//home/wilde/swift/rev/trunk/bin/../libexec/_swiftwrap.staging
1283216169.627 DEBUG 000000 Opening /home/wilde/swiftwork/catsn-20100830-1956-z61dqk05-d-cat-duz412yj/_swiftwrap.staging in cwd /
1283216169.628 DEBUG 000000 1283216169479 Opened /home/wilde/swiftwork/catsn-20100830-1956-z61dqk05-d-cat-duz412yj/_swiftwrap.staging
1283216169.628 DEBUG 000000 Replies: {1 = ARRAY(0x93ce8f0)}
1283216169.628 DEBUG 000000 OUT: len=3, tag=2, flags=0
1283216169.628 DEBUG 000000 OUT: len=78, tag=2, flags=0
1283216169.628 DEBUG 000000 OUT: len=84, tag=2, flags=2
1283216169.628 DEBUG 000000 done sending frags for 2
1283216169.647 DEBUG 000000 Fin flag set
1283216169.653 DEBUG 000000 1283216169479 getFileCBDataIn jobid: 1283216169479, state: 0, tag: 2, err: 4, fin: 0
1283216169.653 DEBUG 000000 Replies: {2 = ARRAY(0x93ce980)}
1283216169.653 DEBUG 000000 OUT: len=9, tag=3, flags=0
1283216169.653 DEBUG 000000 OUT: len=13, tag=3, flags=0
1283216169.653 DEBUG 000000 OUT: len=1, tag=3, flags=0
1283216169.653 DEBUG 000000 OUT: len=3, tag=3, flags=0
1283216169.653 DEBUG 000000 OUT: len=239, tag=3, flags=2
1283216169.653 DEBUG 000000 done sending frags for 3
1283216169.653 DEBUG 000000 Fin flag set
1283216169.653 DEBUG 000000 1283216169479 getFileCBDataIn jobid: 1283216169479, state: 0, tag: 2, err: 4, fin: 2
1283216169.653 DEBUG 000000 Replies: {3 = ARRAY(0x93ce8d0)}
1283216169.653 DEBUG 000000 OUT: len=9, tag=4, flags=0
1283216169.653 DEBUG 000000 OUT: len=13, tag=4, flags=0
1283216169.653 DEBUG 000000 OUT: len=1, tag=4, flags=0
1283216169.653 DEBUG 000000 OUT: len=3, tag=4, flags=0
1283216169.653 DEBUG 000000 OUT: len=2223, tag=4, flags=2
1283216169.653 DEBUG 000000 done sending frags for 4
1283216169.698 DEBUG 000000 Fin flag set
1283216169.902 DEBUG 000000 New request (2)
1283216169.902 DEBUG 000000 Fin flag set
1283216169.902 DEBUG 000000 Processing request
1283216169.902 DEBUG 000000 Cmd is SHUTDOWN
1283216169.902 DEBUG 000000 Shutdown command received
1283216169.902 DEBUG 000000 OUT: len=2, tag=2, flags=3
1283216169.902 DEBUG 000000 done sending frags for 2
com$
----- wilde at mcs.anl.gov wrote:
> Mihael, Justin,
> Im trying to use provider-staging for the first time. It seems to be
> starting the worker in /, and hence staging in fails right away (on
> _swiftwrap).
> Where is the worker supposed to start when using provider staging?
> Ive tried to set the jobdir to /tmp using the <scratch> tag but that
> doesnt seem to be honored.
> Ive tried a few different sites configurations; Im running from
> bridled to communicado using ssh. My most recent is:
>   <pool handle="localhost">
>     <execution provider="coaster" url="communicado.ci.uchicago.edu"
> jobmanager="ssh:local"/>
>     <!-- <profile namespace="globus"
> key="workerManager">passive</profile> -->
>     <profile namespace="globus" key="workersPerNode">8</profile>
>     <profile key="jobThrottle" namespace="karajan">.07</profile>
>     <profile namespace="karajan" key="initialScore">10000</profile>
>     <profile namespace="swift" key="stagingMethod">file</profile>
>     <filesystem provider="local" url="none" />
>     <workdirectory>/home/wilde/swiftwork</workdirectory>
>     <scratch>/tmp/wilde/scratch</scratch>
>   </pool>
> - Mike
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
Michael Wilde
Computation Institute, University of Chicago
Mathematics and Computer Science Division
Argonne National Laboratory
