[Swift-devel] ConcurrentModificationException with coasters
David Kelly dk0966 at cs.ship.edu
Wed Aug 25 22:52:51 CDT 2010
Hello,
Today as I was trying to get a group of MCS machines working with coasters,
I ran into the following error:
java.util.ConcurrentModificationException
        at
java.util.LinkedList$ListItr.checkForComodification(LinkedList.java:761)
        at java.util.LinkedList$ListItr.next(LinkedList.java:696)
        at
org.globus.cog.abstraction.impl.execution.coaster.BootstrapService$ConnectionProcessor.run(BootstrapService.java:251)
        at java.lang.Thread.run(Thread.java:619)
I've tried running the script several more times under the same conditions
(same host, config files and swift version) but can not reproduce it. At
this point everything seems to be working fine, but I thought it might be
useful to report. Script, config files, and log attached.
David
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20100825/608cce86/attachment.html>
Hi There
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20100825/608cce86/attachment.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20100825/608cce86/attachment-0001.obj>
Type: text/xml
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20100825/608cce86/attachment.xml>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20100825/608cce86/attachment-0002.obj>
Type: application/x-gzip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20100825/608cce86/attachment.bin>
