[Swift-devel] GPL licensing question
    Ian Foster
    foster at anl.gov
    Sun Aug 22 23:22:32 CDT 2010
David:
We need to be very careful about including any GPL-licensed code in Swift, as that will make all Swift code GPL. Steve Tuecke can provide more specifics.
Ian.
On Aug 20, 2010, at 11:35 AM, David Kelly wrote:
> Hello,
> My swiftconfig and swiftrun utilities use a module called XML::Simple. It is not included in most standard perl distributions. I would like to include it so users do not have to manually install modules. Perl modules are licensed by the same terms as perl itself - which is the GNU General Public License version 1 (or later at your discretion), or the "artistic license" (http://dev.perl.org/licenses/artistic.html). My understanding is that all Globus projects are required to be under an Apache license.
> I would like to add swiftconfig, swiftrun and associated libraries to the main swift distribution. Can I safely do this without running into any licensing conflicts?
> Thanks,
> David
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20100822/5a273a0f/attachment.html>
