[Swift-devel] Re: Coaster error
Jonathan Monette
jon.monette at gmail.com
Tue Aug 17 13:37:13 CDT 2010
Ok then. Then do you have any ideas on why no more jobs are submitted
through coasters after this error? Here is my sites entry for pads
<pool handle="pads">
<execution jobmanager="local:pbs" provider="coaster"
url="login.pads.ci.uchicago.edu" />
<filesystem provider="local" />
<profile key="maxtime" namespace="globus">3600</profile>
<profile key="internalhostname" namespace="globus">192.5.86.6</profile>
<profile key="workersPerNode" namespace="globus">1</profile>
<profile key="slots" namespace="globus">10</profile>
<profile key="nodeGranularity" namespace="globus">1</profile>
<profile key="maxNodes" namespace="globus">1</profile>
<profile key="queue" namespace="globus">fast</profile>
<profile key="jobThrottle" namespace="karajan">1</profile>
<profile key="initialScore" namespace="karajan">10000</profile>
<workdirectory>/gpfs/pads/swift/jonmon/Swift/work/pads</workdirectory>
</pool>
I have slots set to 10. Does this mean this is the maximum number of
jobs that will be submitted and this number should be increased?
On 8/17/10 1:33 PM, Mihael Hategan wrote:
> The failure to shut down a channel is also ignorable.
> Essentially the worker shuts down before it gets to acknowledge the
> shutdown command. I guess this could be fixed, but for now ignore it.
> On Tue, 2010-08-17 at 13:21 -0500, Jonathan Monette wrote:
>> Or so the qdel error I am seeing is ignorable? And I am assuming that
>> the shutdown failure has something to do with the jobs being run because
>> when I run a smaller data set (10 images instead of 1300 images) the
>> shutdown error happens at the end of the workflow and I also get the error
>> Failed to shut down channel
>> org.globus.cog.karajan.workflow.service.channels.ChannelException:
>> Invalid channel: 1338035062: {}
>> at
>> org.globus.cog.karajan.workflow.service.channels.ChannelManager.getMetaChannel(ChannelManager.java:442)
>> at
>> org.globus.cog.karajan.workflow.service.channels.ChannelManager.getMetaChannel(ChannelManager.java:422)
>> at
>> org.globus.cog.karajan.workflow.service.channels.ChannelManager.shutdownChannel(ChannelManager.java:411)
>> at
>> org.globus.cog.karajan.workflow.service.channels.ChannelManager.handleChannelException(ChannelManager.java:284)
>> at
>> org.globus.cog.karajan.workflow.service.channels.AbstractStreamKarajanChannel.handleChannelException(AbstractStreamKarajanChannel.java:83)
>> at
>> org.globus.cog.karajan.workflow.service.channels.AbstractStreamKarajanChannel$Sender.run(AbstractStreamKarajanChannel.java:257)
>> On 8/17/10 12:43 PM, Mihael Hategan wrote:
>>> On Tue, 2010-08-17 at 12:08 -0500, Jonathan Monette wrote:
>>>> Ok. Have ran more tests on this problem. I am running on both
>>>> localhost and pads. In the first stage of my workflow I run on
>>>> localhost to collect some metadata. I then use this metadata to
>>>> reproject the images submitting these jobs to pads. All the images are
>>>> reprojected and completes without error. After this the coasters is
>>>> waiting for more jobs to submit to the workers while localhost is
>>>> collecting more metadata. I believe coasters starts to shutdown some of
>>>> the workers because they are idle and wants to free the resources on the
>>>> machine(am I correct so far?)
>>> You are.
>>>> During the shutdown some workers are
>>>> shutdown successfully but there is always 1 or 2 that fail to shutdown
>>>> and I get the qdel error 153 I mentioned yesterday. If coasters fails
>>>> to shutdown a job does the service terminate?
>>> No. The qdel part is not critical and is used when workers don't shut
>>> down cleanly or on time.
>>>> I ask this because after
>>>> the job fails to shutdown there are no more jobs being submitted in the
>>>> queue and my script hangs since it is waiting for the next stage in my
>>>> workflow to complete. Is there a coaster parameter that lets coasters
>>>> know to not shutdown the workers even if they become idle for a bit or
>>>> is this a legitimate error in coasters?
>>> You are assuming that the shutdown failure has something to do with jobs
>>> not being run. I do not think that's necessarily right.
Jon
Computers are incredibly fast, accurate, and stupid. Human beings are incredibly slow, inaccurate, and brilliant. Together they are powerful beyond imagination.
- Albert Einstein
