[Swift-devel] How to update the swift command for usage tracking?
Michael Wilde
wilde at mcs.anl.gov
Tue Aug 10 17:31:55 CDT 2010
----- "Mihael Hategan" <hategan at mcs.anl.gov> wrote:
> On Tue, 2010-08-10 at 11:50 -0600, Michael Wilde wrote:
> > A thought on this: could/should the swift command be moved from
> cog/etc to modules/swift?
> The swift command is not in cog/etc. It gets generated from a
> template
> there and then combined with some swift specific things.
> We could bypass that and store it plainly in swift/bin.
Yes, I think David should it do that way.
I suspect he's adding large enough of a code fragment that we dont want to maintain this via <replace> in build.xml. ANd it will be more convenient for other developers to have access to the swift command via swift svn.
- Mike
> > Or should Swift developers also be CoG committers?
> > - Mike
> > ----- "Michael Wilde" <wilde at mcs.anl.gov> wrote:
> > > Mihael, can you provide guidance for how David should proceed?
> > > Thanks,
> > > Mike
> > > ----- Forwarded Message -----
> > > From: "David Kelly" <dk0966 at cs.ship.edu>
> > > To: wilde at mcs.anl.gov
> > > Sent: Tuesday, August 10, 2010 12:34:50 PM GMT -06:00 US/Canada
> > > Central
> > > Subject: Re: Swift listener
> > > Hi Mike,
> > > I wanted to add the new swift shell script with usage tracking
> last
> > > night, but noticed that the swift shell script is not directly a
> part
> > > of SVN. It gets generated during "ant dist" based on
> > > cog/etc/unix/launcher-template. I think I can get around this by
> > > editing cog/modules/swift/build.xml. The <replace> option should
> allow
> > > me to add my stuff from there. Just wanted to check with you to
> make
> > > sure this was the way I should do it before I submitted anything.
> > > Thanks,
> > > David
> > > Michael Wilde
> > > Computation Institute, University of Chicago
> > > Mathematics and Computer Science Division
> > > Argonne National Laboratory
> > > _______________________________________________
> > > Swift-devel mailing list
> > > Swift-devel at ci.uchicago.edu
> > > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
Michael Wilde
