[Swift-devel] Re: How to update the swift command for usage tracking?
Mihael Hategan hategan at mcs.anl.gov
Tue Aug 10 13:07:31 CDT 2010
The replace strategy from swift/build.xml is what we have used so far.
On Tue, 2010-08-10 at 11:38 -0600, Michael Wilde wrote:
> Mihael, can you provide guidance for how David should proceed?
> Thanks,
> Mike
> ----- Forwarded Message -----
> From: "David Kelly" <dk0966 at cs.ship.edu>
> To: wilde at mcs.anl.gov
> Sent: Tuesday, August 10, 2010 12:34:50 PM GMT -06:00 US/Canada Central
> Subject: Re: Swift listener
> Hi Mike,
> I wanted to add the new swift shell script with usage tracking last night, but noticed that the swift shell script is not directly a part of SVN. It gets generated during "ant dist" based on cog/etc/unix/launcher-template. I think I can get around this by editing cog/modules/swift/build.xml. The <replace> option should allow me to add my stuff from there. Just wanted to check with you to make sure this was the way I should do it before I submitted anything.
> Thanks,
> David
