[Swift-devel] decaying number of coaster jobs leaves some tasks unfinished
Mihael Hategan hategan at mcs.anl.gov
Mon Aug 9 16:49:30 CDT 2010
That error might be related. Can I have the full log?
On Mon, 2010-08-09 at 17:44 -0400, Glen Hocky wrote:
> Hey everyone,
> I've been trying to run some short jobs in the "fast" queue on pads.
> That means I need to keep the wall time under 1 hour, and my tasks are
> around 20 min.  What's been happening, at least for a smallish number
> of jobs, is that swift decreases the number of jobs submitted to the
> queue as the number of tasks is reduced and at the end, some tasks
> remain unfinished while no jobs are in the queue, and this continues
> indefinately.
> The following is one sites entry where I reproducibly had this problem
> for 70 tasks
>             <execution provider="coaster" url="none"
>         jobManager="local:pbs"/>
>             <!--<profile namespace="globus"
>         key="queue">fast</profile>-->
>             <profile namespace="globus" key="maxtime">3600</profile>
>         key="maxwalltime">00:25:00</profile>
>         key="workersPerNode">1</profile>
>         key="internalHostname">172.5.86.5</profile>
>             <profile namespace="globus" key="slots">120</profile>
>         key="nodeGranularity">1</profile>
>             <profile namespace="globus" key="maxNodes">1</profile>
>             <profile namespace="karajan"
>         key="jobThrottle">0.99</profile>
>         key="initialScore">10000</profile>
>         key="project">CI-CCR000013</profile>
>             <gridftp  url="local://localhost" />
>             <scratch>/tmp</scratch>
>          <workdirectory>/home/hockyg/reichman/glassy_dynamics/code/swift/run/real</workdirectory>
> There are also some of this type of error
> Exception caught while unregistering channel
>         org.globus.cog.karajan.workflow.service.channels.ChannelException: Trying to bind invalid channel (2027063355: {}) to 60652275: {}
>                 at
>         org.globus.cog.karajan.workflow.service.channels.MetaChannel.bind(MetaChannel.java:67)
>                 at
>         org.globus.cog.karajan.workflow.service.channels.ChannelManager.unregisterChannel(ChannelManager.java:401)
>                 at
>         org.globus.cog.karajan.workflow.service.channels.ChannelManager.shutdownChannel(ChannelManager.java:411)
>                 at
>         org.globus.cog.karajan.workflow.service.channels.ChannelManager.handleChannelException(ChannelManager.java:284)
>                 at
>         org.globus.cog.karajan.workflow.service.channels.AbstractStreamKarajanChannel.handleChannelException(AbstractStreamKarajanChannel.java:83)
>                 at
>         org.globus.cog.karajan.workflow.service.channels.AbstractStreamKarajanChannel$Sender.run(AbstractStreamKarajanChannel.java:257)
> but i'm not sure that's related...
> Running with "Swift svn swift-r3432 (swift modified locally)
> cog-r2829"
> Swift output went something like
> Progress:  Submitted:69  Active:1  Finished successfully:1
> Progress:  Submitted:67  Active:3  Finished successfully:1
> Progress:  Submitted:66  Active:4  Finished successfully:1
> Progress:  Submitted:65  Active:5  Finished successfully:1
> Progress:  Submitted:64  Active:6  Finished successfully:1
> Progress:  Submitted:61  Active:9  Finished successfully:1
> Progress:  Submitted:58  Active:12  Finished successfully:1
> Progress:  Submitted:57  Active:13  Finished successfully:1
> Progress:  Submitted:54  Active:16  Finished successfully:1
> Progress:  Submitted:52  Active:18  Finished successfully:1
> Progress:  Submitted:51  Active:19  Finished successfully:1
> Progress:  Submitted:50  Active:20  Finished successfully:1
> Progress:  Submitted:49  Active:21  Finished successfully:1
> Progress:  Submitted:48  Active:22  Finished successfully:1
> Progress:  Submitted:41  Active:29  Finished successfully:1
> Progress:  Submitted:38  Active:32  Finished successfully:1
> Progress:  Submitted:37  Active:33  Finished successfully:1
> Progress:  Submitted:35  Active:35  Finished successfully:1
> Progress:  Submitted:31  Active:39  Finished successfully:1
> Progress:  Submitted:30  Active:40  Finished successfully:1
> Progress:  Submitted:26  Active:44  Finished successfully:1
> Progress:  Submitted:26  Active:43  Checking status:1  Finished
> successfully:1
> Progress:  Submitted:26  Active:43  Finished successfully:2
> Progress:  Submitted:26  Active:42  Checking status:1  Finished
> successfully:2
> Progress:  Submitted:25  Active:42  Checking status:1  Finished
> successfully:3
> Progress:  Submitted:25  Active:41  Checking status:1  Finished
> successfully:4
> Progress:  Submitted:25  Active:41  Finished successfully:5
> Progress:  Submitted:25  Active:40  Checking status:1  Finished
> successfully:5
> Progress:  Submitted:25  Active:39  Checking status:1  Finished
> successfully:6
> Progress:  Submitted:24  Active:40  Finished successfully:7
> Progress:  Submitted:24  Active:39  Checking status:1  Finished
> successfully:7
> Progress:  Submitted:24  Active:38  Checking status:1  Finished
> successfully:8
> Progress:  Submitted:24  Active:38  Finished successfully:9
> Progress:  Submitted:24  Active:37  Checking status:1  Finished
> successfully:9
> Progress:  Submitted:24  Active:35  Checking status:1  Finished
> successfully:11
> Progress:  Submitted:23  Active:35  Checking status:1  Finished
> successfully:12
> Progress:  Submitted:22  Active:35  Checking status:1  Finished
> successfully:13
> Progress:  Submitted:22  Active:35  Finished successfully:14
> Progress:  Submitted:22  Active:34  Checking status:1  Finished
> successfully:14
> Progress:  Submitted:21  Active:34  Checking status:1  Finished
> successfully:15
> Progress:  Submitted:21  Active:34  Finished successfully:16
> Progress:  Submitted:21  Active:33  Checking status:1  Finished
> successfully:16
> Progress:  Submitted:21  Active:33  Finished successfully:17
> Progress:  Submitted:20  Active:32  Checking status:1  Finished
> successfully:18
> Progress:  Submitted:20  Active:32  Finished successfully:19
> Progress:  Submitted:20  Active:31  Checking status:1  Finished
> successfully:19
> Progress:  Submitted:19  Active:31  Finished successfully:21
> Progress:  Submitted:19  Active:30  Checking status:1  Finished
> successfully:21
> Progress:  Submitted:18  Active:30  Checking status:1  Finished
> successfully:22
> Progress:  Submitted:18  Active:29  Checking status:1  Finished
> successfully:23
> Progress:  Submitted:18  Active:28  Checking status:1  Finished
> successfully:24
> Progress:  Submitted:17  Active:29  Finished successfully:25
> Progress:  Submitted:17  Active:28  Checking status:1  Finished
> successfully:25
> Progress:  Submitted:17  Active:27  Checking status:1  Finished
> successfully:26
> Progress:  Submitted:17  Active:26  Checking status:1  Finished
> successfully:27
> Progress:  Submitted:17  Active:25  Checking status:1  Finished
> successfully:28
> Progress:  Submitted:17  Active:24  Checking status:1  Finished
> successfully:29
> Progress:  Submitted:16  Active:25  Finished successfully:30
> Progress:  Submitted:16  Active:24  Checking status:1  Finished
> successfully:30
> Progress:  Submitted:15  Active:24  Checking status:1  Finished
> successfully:31
> Progress:  Submitted:15  Active:24  Finished successfully:32
> Progress:  Submitted:15  Active:23  Checking status:1  Finished
> successfully:32
> Progress:  Submitted:14  Active:24  Finished successfully:33
> Progress:  Submitted:14  Active:23  Checking status:1  Finished
> successfully:33
> Progress:  Submitted:14  Active:22  Checking status:1  Finished
> successfully:34
> Progress:  Submitted:14  Active:22  Finished successfully:35
> Progress:  Submitted:14  Active:21  Checking status:1  Finished
> successfully:35
> Progress:  Submitted:13  Active:22  Finished successfully:36
> Progress:  Submitted:13  Active:20  Checking status:1  Finished
> successfully:37
> Progress:  Submitted:12  Active:21  Finished successfully:38
> Progress:  Submitted:12  Active:20  Checking status:1  Finished
> successfully:38
> Progress:  Submitted:12  Active:19  Checking status:1  Finished
> successfully:39
> Progress:  Submitted:12  Active:19  Finished successfully:40
> Progress:  Submitted:12  Active:18  Checking status:1  Finished
> successfully:40
> Progress:  Submitted:12  Active:17  Checking status:1  Finished
> successfully:41
> Progress:  Submitted:11  Active:17  Checking status:1  Finished
> successfully:42
> Progress:  Submitted:11  Active:17  Finished successfully:43
> Progress:  Submitted:11  Active:16  Checking status:1  Finished
> successfully:43
> Progress:  Submitted:11  Active:15  Checking status:1  Finished
> successfully:44
> Progress:  Submitted:10  Active:16  Finished successfully:45
> Progress:  Submitted:3  Active:22  Finished successfully:46
> Progress:  Submitted:3  Active:21  Checking status:1  Finished
> successfully:46
> Progress:  Submitted:3  Active:19  Finished successfully:49
> Progress:  Submitted:2  Active:20  Finished successfully:49
> Progress:  Submitted:1  Active:21  Finished successfully:49
> Progress:  Submitted:1  Active:15  Finished successfully:55
> Progress:  Submitted:1  Active:14  Checking status:1  Finished
> successfully:55
> Progress:  Submitted:1  Active:14  Finished successfully:56
> Progress:  Submitted:1  Active:13  Checking status:1  Finished
> successfully:56
> Progress:  Submitted:1  Active:12  Checking status:1  Finished
> successfully:57
> Progress:  Submitted:1  Active:12  Finished successfully:58
> Progress:  Submitted:1  Active:11  Checking status:1  Finished
> successfully:58
> Progress:  Submitted:1  Active:10  Checking status:1  Finished
> successfully:59
> Progress:  Submitted:1  Active:10  Finished successfully:60
> Progress:  Submitted:1  Active:8  Checking status:1  Finished
> successfully:61
> Progress:  Submitted:1  Active:8  Finished successfully:62
> Progress:  Submitted:1  Active:7  Checking status:1  Finished
> successfully:62
> Progress:  Submitted:1  Active:7  Finished successfully:63
> Progress:  Submitted:1  Active:6  Checking status:1  Finished
> successfully:63
> Progress:  Submitted:1  Active:4  Checking status:1  Finished
> successfully:65
> Progress:  Submitted:1  Active:3  Checking status:1  Finished
> successfully:66
> Progress:  Submitted:1  Active:3  Finished successfully:67
> Progress:  Submitted:1  Active:2  Checking status:1  Finished
> successfully:67
> Progress:  Submitted:1  Active:2  Finished successfully:68
> Progress:  Submitted:1  Active:1  Checking status:1  Finished
> successfully:68
> Progress:  Submitted:1  Finished successfully:70
> etc
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
