[Swift-devel] problem compiling latest version of swift
Glen Hocky
hockyg at uchicago.edu
Tue Aug 3 12:22:11 CDT 2010
For some reason I haven't been able to compile swift from the svn on any of
the machine's I've tried. not sure if something has changed since the last
time I had to do it many months ago.
attached is the log of ant failing as well as details on the repositories I
used, etc.
any suggestions?
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20100803/5d43f969/attachment.html>
$ svn info
Path: .
URL: https://cogkit.svn.sourceforge.net/svnroot/cogkit/trunk/current/src/cog/modules
Repository Root: https://cogkit.svn.sourceforge.net/svnroot/cogkit
Repository UUID: 5b74d2a0-fa0e-0410-85ed-ffba77ec0bde
Revision: 2829
Node Kind: directory
Schedule: normal
Last Changed Author: hategan
Last Changed Rev: 2829
Last Changed Date: 2010-07-28 14:32:48 -0500 (Wed, 28 Jul 2010)
$ svn info
Path: .
URL: https://svn.ci.uchicago.edu/svn/vdl2/trunk
Repository Root: https://svn.ci.uchicago.edu/svn/vdl2
Repository UUID: e2bb083e-7f23-0410-b3a8-8253ac9ef6d8
Revision: 3496
Schedule: normal
Last Changed Author: jonmon
Last Changed Rev: 3494
Last Changed Date: 2010-07-30 13:56:11 -0500 (Fri, 30 Jul 2010)
$ ant dist
Buildfile: build.xml
generateVersion:
antlr:
[java] ANTLR Parser Generator Version 2.7.5 (20050128) 1989-2005 jGuru.com
[java] resources/swiftscript.g:1028: warning:nondeterminism upon
[java] resources/swiftscript.g:1028: k==1:LBRACK
[java] resources/swiftscript.g:1028: k==2:ID,STRING_LITERAL,LBRACK,LPAREN,AT,PLUS,MINUS,STAR,NOT,INT_LITERAL,FLOAT_LITERAL,"true","false"
[java] resources/swiftscript.g:1028: between alt 1 and exit branch of block
compileSchema:
[java] Time to build schema type system: 0.511 seconds
[java] Time to generate code: 1.268 seconds
[java] Time to compile code: 2.541 seconds
[java] Compiled types to: /autonfs/home/hockyg/swift/cog/modules/swift/../../modules/swift/lib/vdldefinitions.jar
dist:
dist:
log4j.properties:
log4j.check.module:
log4j.properties.init:
[delete] Deleting: /autonfs/home/hockyg/swift/cog/modules/swift/dist/swift-svn/etc/log4j.properties
[delete] Deleting: /autonfs/home/hockyg/swift/cog/modules/swift/dist/swift-svn/CHANGES.txt
[copy] Copying 1 file to /autonfs/home/hockyg/swift/cog/modules/swift/dist/swift-svn/etc
log4j.properties.update:
build.dependencies:
dependencies:
create.dependency.log:
delete.dependency.log.1:
[delete] Deleting: /autonfs/home/hockyg/swift/cog/dependency.log.dist
deps:
dep:
dep.1:
dist:
dist:
log4j.properties:
log4j.check.module:
build.dependencies:
dependencies:
deps:
dep:
dep.1:
dist:
dist:
log4j.properties:
log4j.check.module:
build.dependencies:
dependencies:
deps:
dep:
dep.1:
dist:
dist:
log4j.properties:
log4j.check.module:
build.dependencies:
dependencies:
deps:
dep:
dep.1:
dist:
dist:
log4j.properties:
log4j.check.module:
[java] Warning: source log (/autonfs/home/hockyg/swift/cog/modules/jglobus/../../modules/jglobus/CHANGES.txt) does not exist
build.dependencies:
dependencies:
deps:
[echo] [jglobus]: DIST
[echo] [jglobus]: JARCOPY
delete.jar:
compile:
[echo] [jglobus]: COMPILE
copy.resources:
jar:
[echo] [jglobus]: JAR (cog-jglobus-1.7.0.jar)
[jar] Building jar: /autonfs/home/hockyg/swift/cog/modules/swift/dist/swift-svn/lib/cog-jglobus-1.7.0.jar
create:
launcher:
create.launcher:
launcher:
create.launcher:
launcher:
create.launcher:
launcher:
create.launcher:
launcher:
create.launcher:
launcher:
create.launcher:
launcher:
create.launcher:
launcher:
create.launcher:
launcher:
create.launcher:
launcher:
create.launcher:
launcher:
create.launcher:
launcher:
create.launcher:
launcher:
create.launcher:
launcher:
create.launcher:
deploy.examples:
do.deploy.examples:
[copy] Copying 1 file to /autonfs/home/hockyg/swift/cog/modules/swift/dist/swift-svn/lib
dep:
dep.1:
dist:
dist:
log4j.properties:
log4j.check.module:
[java] Warning: source log (/autonfs/home/hockyg/swift/cog/modules/util/../../modules/util/CHANGES.txt) does not exist
build.dependencies:
dependencies:
deps:
[echo] [util]: DIST
[echo] [util]: JARCOPY
delete.jar:
compile:
[echo] [util]: COMPILE
copy.resources:
jar:
[echo] [util]: JAR (cog-util-0.92.jar)
create:
launcher:
create.launcher:
deploy.examples:
do.deploy.examples:
[echo] [abstraction-common]: DIST
[echo] [abstraction-common]: JARCOPY
delete.jar:
compile:
[echo] [abstraction-common]: COMPILE
copy.resources:
jar:
[echo] [abstraction-common]: JAR (cog-abstraction-common-2.4.jar)
create:
launcher:
create.launcher:
launcher:
create.launcher:
launcher:
create.launcher:
launcher:
create.launcher:
example.launcher:
create.example.launcher:
[echo] [abstraction-common]: EXAMPLE LAUNCHER examples/hierarchical-queue-handler
example.launcher:
[echo] [abstraction-common]: EXAMPLE LAUNCHER examples/hierarchical-set-handler
launcher:
create.launcher:
example.launcher:
[echo] [abstraction-common]: EXAMPLE LAUNCHER examples/taskgraph-2-xml
launcher:
create.launcher:
launcher:
create.launcher:
example.launcher:
[echo] [abstraction-common]: EXAMPLE LAUNCHER examples/xml-2-taskgraph
launcher:
create.launcher:
deploy.examples:
do.deploy.examples:
dep:
dep.1:
dist:
dist:
log4j.properties:
log4j.check.module:
build.dependencies:
dependencies:
deps:
dep:
dep.1:
dep:
dep.1:
dep:
dep.1:
[echo] [provider-gt2]: DIST
[echo] [provider-gt2]: JARCOPY
delete.jar:
[echo] [provider-gt2]: DELETE.JAR (cog-provider-gt2-2.4.jar)
compile:
[echo] [provider-gt2]: COMPILE
[javac] Compiling 16 source files to /autonfs/home/hockyg/swift/cog/modules/provider-gt2/build
[javac] /autonfs/home/hockyg/swift/cog/modules/provider-gt2/src/org/globus/cog/abstraction/impl/execution/gt2/JobSubmissionTaskHandler.java:332: cannot find symbol
[javac] symbol : method getStageIn()
[javac] location: interface org.globus.cog.abstraction.interfaces.JobSpecification
[javac] boolean staging = notEmpty(spec.getStageIn())
[javac] ^
[javac] /autonfs/home/hockyg/swift/cog/modules/provider-gt2/src/org/globus/cog/abstraction/impl/execution/gt2/JobSubmissionTaskHandler.java:333: cannot find symbol
[javac] symbol : method getStageOut()
[javac] || notEmpty(spec.getStageOut());
[javac] ^
[javac] /autonfs/home/hockyg/swift/cog/modules/provider-gt2/src/org/globus/cog/abstraction/impl/execution/gt2/JobSubmissionTaskHandler.java:364: cannot find symbol
[javac] addStagingSpec(spec.getStageIn(), rsl, "file_stage_in");
[javac] ^
[javac] /autonfs/home/hockyg/swift/cog/modules/provider-gt2/src/org/globus/cog/abstraction/impl/execution/gt2/JobSubmissionTaskHandler.java:365: cannot find symbol
[javac] addStagingSpec(spec.getStageOut(), rsl, "file_stage_out");
[javac] ^
[javac] /autonfs/home/hockyg/swift/cog/modules/provider-gt2/src/org/globus/cog/abstraction/impl/execution/gt2/JobSubmissionTaskHandler.java:381: incompatible types
[javac] found : java.lang.Object
[javac] required: java.lang.String
[javac] for (String key : spec.getAttributeNames()) {
[javac] ^
[javac] /autonfs/home/hockyg/swift/cog/modules/provider-gt2/src/org/globus/cog/abstraction/impl/execution/gt2/JobSubmissionTaskHandler.java:498: incompatible types
[javac] for (String arg : spec.getArgumentsAsList()) {
[javac] ^
[javac] Note: Some input files use or override a deprecated API.
[javac] Note: Recompile with -Xlint:deprecation for details.
[javac] Note: Some input files use unchecked or unsafe operations.
[javac] Note: Recompile with -Xlint:unchecked for details.
[javac] 6 errors
BUILD FAILED
/autonfs/home/hockyg/swift/cog/modules/swift/build.xml:73: The following error occurred while executing this line:
/autonfs/home/hockyg/swift/cog/mbuild.xml:444: The following error occurred while executing this line:
/autonfs/home/hockyg/swift/cog/mbuild.xml:79: The following error occurred while executing this line:
/autonfs/home/hockyg/swift/cog/mbuild.xml:52: The following error occurred while executing this line:
/autonfs/home/hockyg/swift/cog/modules/swift/dependencies.xml:4: The following error occurred while executing this line:
/autonfs/home/hockyg/swift/cog/mbuild.xml:163: The following error occurred while executing this line:
/autonfs/home/hockyg/swift/cog/mbuild.xml:168: The following error occurred while executing this line:
/autonfs/home/hockyg/swift/cog/modules/karajan/build.xml:59: The following error occurred while executing this line:
/autonfs/home/hockyg/swift/cog/modules/karajan/dependencies.xml:4: The following error occurred while executing this line:
/autonfs/home/hockyg/swift/cog/modules/abstraction/build.xml:58: The following error occurred while executing this line:
/autonfs/home/hockyg/swift/cog/modules/abstraction/dependencies.xml:7: The following error occurred while executing this line:
/autonfs/home/hockyg/swift/cog/modules/provider-gt2/build.xml:59: The following error occurred while executing this line:
/autonfs/home/hockyg/swift/cog/mbuild.xml:465: The following error occurred while executing this line:
/autonfs/home/hockyg/swift/cog/mbuild.xml:228: Compile failed; see the compiler error output for details.
Total time: 55 seconds
