[Swift-devel] Re: Problem with incorrect host cert DN in coaster GSI authentication
    Mihael Hategan
    hategan at mcs.anl.gov
    Thu Apr 29 18:18:04 CDT 2010
On Thu, 2010-04-29 at 17:34 -0500, Yi Zhu wrote:
> HI,
>  I've tried it with "gt2:pbs", and got a "qsub not found" error, for
> further investigation, I  pulled the env used by globus,and  found
> that there is no "/opt/torque-2.3.6/bin/qsub" under the PATH= ,I think
> that's why cause  "qsub not found" problem.
> Any suggested solution ?
Two actually.
1. This is for the qsub problem: you can add the relevant environment
variables (for Torque) in sites.xml.
2. This is for the DN issue with gt2:gt2:pbs: Edit /etc/hosts and make
sure that the expected DN is the first entry for the internal IP passed
to the coaster service. If the entry is not in there at all, add it.
This is a way to impersonate a Globus service and possibly do a
man-in-the-middle thing, but it may also work to fix the DN mismatch
problem.
Mihael
