[Swift-devel] Re: coaster on EC2 (error log)
Mihael Hategan
hategan at mcs.anl.gov
Tue Apr 27 13:59:44 CDT 2010
On Tue, 2010-04-27 at 13:18 -0500, Yi Zhu wrote:
> I also checked the coaster log in server node, it shows it need a
> binary file called gmd5sum,
It shows it looked for gmd5sum and didn't find it. So it tries md5sum
instead. I believe gmd5sum is the default on OS X and the reason why it
looks for it. In any event, if the coaster process doesn't fail saying
"didn't find gmd5sum or md5sum", then that's likely not your problem,
and judging from the log below which says "Computed checksum...", md5sum
was found.
> coaster-bootstrap-11894108087.log
> using plain mode
> BS: http://tp-login2.ci.uchicago.edu:37470
> which: no gmd5sum in
> (/opt/vdt-1.10.1/gums/scripts:/opt/vdt-1.10.1/prima/bin:/opt/vdt-1.10.1/cert-scripts/bin:/opt/vdt-1.10.1/glite/sbin:/opt/vdt-1.10.1/glite/bin:/opt/vdt-1.10.1/jdk1.5/bin:/opt/vdt-1.10.1/edg/sbin:/opt/vdt-1.10.1/gip/bin:/opt/vdt-1.10.1/gpt/sbin:/opt/vdt-1.10.1/globus/bin:/opt/vdt-1.10.1/globus/sbin:/opt/vdt-1.10.1/wget/bin:/opt/vdt-1.10.1/logrotate/sbin:/opt/vdt-1.10.1/perl/bin:/opt/pacman-3.26/bin:/opt/vdt-1.10.1/vdt/sbin:/opt/vdt-1.10.1/vdt/bin:/opt/pacman-3.26/bin:/usr/local/bin:/bin:/usr/bin)
> Expected checksum: acab90e149a0188fbc963803a42156c5
> Computed checksum: acab90e149a0188fbc963803a42156c5
