[Swift-devel] build errors on the stable branch
Allan Espinosa aespinosa at cs.uchicago.edu
Mon Apr 26 19:39:12 CDT 2010
With a fresh checkout/ export in cog 4.1.7  branch and swift 1.0
branch,  I get the following build errors:
    [javac] /autonfs/home/aespinosa/work/cogkit/modules/swift/src/org/globus/swift/catalog/util/ProfileParserException.java:23:
warning: unmappable character for encoding UTF8
    [javac]  * @author Jens-S. V�ckler
    [javac]                     ^
    [javac] /autonfs/home/aespinosa/work/cogkit/modules/swift/src/org/globus/swift/catalog/util/Separator.java:25:
    [javac]                     ^
    [javac] /autonfs/home/aespinosa/work/cogkit/modules/swift/src/org/griphyn/vdl/karajan/lib/SetFieldValue.java:51:
cannot find symbol
    [javac] symbol  : method getLast()
    [javac] location: class org.griphyn.vdl.mapping.Path
    [javac]                                 markAsAvailable(stack,
leaf.getParent(), leaf.getPathFromRoot().getLast());
    [javac]
    [javac] Note:
/autonfs/home/aespinosa/work/cogkit/modules/swift/src/org/griphyn/vdl/karajan/VDL2ErrorTranslator.java
uses or overrides a deprecated API.
    [javac] Note: Recompile with -Xlint:deprecation for details.
    [javac] 1 error
    [javac] 5 warnings
BUILD FAILED
/autonfs/home/aespinosa/work/cogkit/modules/swift/build.xml:73: The
following error occurred while executing this line:
/autonfs/home/aespinosa/work/cogkit/mbuild.xml:464: The following
/autonfs/home/aespinosa/work/cogkit/mbuild.xml:228: Compile failed;
see the compiler error output for details.
Total time: 24 seconds
This doesn't occur in a fresh checkout/ export of cog-trunk and swift-trunk
My build config:
$ java -version
java version "1.6.0_03"
Java(TM) SE Runtime Environment (build 1.6.0_03-b05)
Java HotSpot(TM) Server VM (build 1.6.0_03-b05, mixed mode)
I tried building with java1.5 and got the same build errors as well.
-Allan
Allan M. Espinosa <http://amespinosa.wordpress.com>
PhD student, Computer Science
University of Chicago <http://people.cs.uchicago.edu/~aespinosa>
