[Swift-devel] Coaster error in RaptorLoops run
    Wenjun Wu
    wwj at ci.uchicago.edu
    Mon Apr 26 16:01:06 CDT 2010
Sure. My config files are under the folder:
/gpfs/pads/oops/scienceportal/swift-svn/etc
the logs can be found at
/gpfs/pads/oops/scienceportal/scriptadmin/oops-raptorloop/test/RaptorLoops-20100426-1314-tna3q0a6.log
Wenjun
> Wenjun, can you post more details on the problem you describe below, to the swift-devel list (cc'ed here) pointing Mihael to a directory with all your logs and config files?
> Thanks,
> Mike
> ----- "wenjun wu"<wwjag at mcs.anl.gov>  wrote:
>> Hi Mike,
>>      Now I can run raptorloop locally but when I launch the jobs to
>> PADS
>> through coaster:ssh:pbs, I keep getting the following exceptions
>> after the swift finishes the most steps.
>> 2010-04-26 13:27:25,408-0500 INFO  AbstractStreamKarajanChannel
>> 01173289853: Channel shut down
>> java.lang.Throwable
>>           at
>> org.globus.cog.karajan.workflow.service.channels.AbstractTCPChannel.close(AbstractTCPChannel.java:97)
>>           at
>> org.globus.cog.karajan.workflow.service.channels.MetaChannel.close(MetaChannel.java:87)
>>           at
>> org.globus.cog.abstraction.impl.execution.coaster.ServiceManager.statusChanged(ServiceManager.java:232)
>>           at
>> org.globus.cog.abstraction.impl.common.task.TaskImpl.notifyListeners(TaskImpl.java:236)
>>           at
>> org.globus.cog.abstraction.impl.common.task.TaskImpl.setStatus(TaskImpl.java:224)
>>           at
>> org.globus.cog.abstraction.impl.common.task.TaskImpl.setStatus(TaskImpl.java:253)
>> at
>> org.globus.cog.abstraction.impl.ssh.execution.JobSubmissionTaskHandler.SSHTaskStatusChanged(JobSubmissionTaskHandler.java:193)
>>           at
>> org.globus.cog.abstraction.impl.ssh.SSHRunner.notifyListeners(SSHRunner.java:84)
>>           at
>> org.globus.cog.abstraction.impl.ssh.SSHRunner.run(SSHRunner.java:43)
>> at java.lang.Thread.run(Thread.java:595)
>> 2010-04-26 13:27:25,408-0500 INFO  ChannelManager Handling channel
>> exception
>> java.io.IOException: Stream closed.        at
>> java.net.PlainSocketImpl.available(PlainSocketImpl.java:428)
>>           at
>> java.net.SocketInputStream.available(SocketInputStream.java:217)
>>           at
>> org.globus.gsi.gssapi.net.GssInputStream.available(GssInputStream.java:107)
>> at
>> org.globus.cog.karajan.workflow.service.channels.AbstractStreamKarajanChannel.step(AbstractStreamKarajanChannel.java:113)
>>           at
>> org.globus.cog.karajan.workflow.service.channels.AbstractStreamKarajanChannel$Multiplexer.run(AbstractStreamKarajanChannel.java:365)
>> Progress:  Finished successfully:7
>> Progress:  Active:1  Finished successfully:7
>> Progress:  Checking status:1  Finished successfully:7
>> Progress:  Finished successfully:8
>> Wenjun
>>> was: Re: notes from todays meeting
>>> Hi Aashish,
>>> Wenjun and Tom are integrated the latest OOPS scripts into the
>> portal for Web execution.
>>> Wenjun is getting errors, as below. I suspect he's missing some
>> parameters or has incorrect parameters or inputs.
>>> Can you send to Wenjun the latest parameters (ie shell calling
>> examples) to run Loops, RaptorLoops, and RaptorLoops with prep stage?
>>> Best thing to do is quickly update README with the lastest shell
>> invocation lines and check it in; then Wenjun can verify that the
>> latest documented invocation instructions work for other people (which
>> will be useful for the OOPS group too!)
>>> I cant get to this till late today or early this weekend, so any
>> help you can offer will be great.
>>> Thanks!
>>> - Mike
>>>> Hi Mike,
>>>>     I run the raptorloop.sh and got the following error. Any clue?
>>>> Wenjun
>>>> [wwj at login1 wwjtest]$ run.raptorloops.sh -target T1af7 -prepTar
>>>> T1af7.prep.tar.gz -templatesPerJob 800
>>>> Running in
>> /gpfs/pads/oops/scienceportal/oops-svn/oops/protlib2-0422/wwjtest/run.raptorloops.9229
>>>> Running RaptorLoops with settings: target=T1af7 seqFile=
>>>> prepTar=T1af7.prep.tar.gz templatesPerJob=800 templateList=
>> nModels=
>>>> nSim=4 execsite=localhost maxSlots=16 resume= rlog=
>>>> Running from host with compute-node reachable address of
>> 172.5.86.5
>>>> protlib2 home is
>>>> cp: warning: source file
>> `/gpfs/pads/oops/scienceportal/oops-svn/oops/protlib2-0422/swift/RaptorOut.map'
>>>> specified more than once
>> `/gpfs/pads/oops/scienceportal/oops-svn/oops/protlib2-0422/swift/TemplateList.map'
>>>> cp: missing destination file operand after `.'
>>>> Try `cp --help' for more information.
>>>> basename: missing operand
>>>> Try `basename --help' for more information.
>>>> Variable nModels defined in scope 7122710 shadows variable of same
>>>> name
>>>> in scope 4890830
>>>> Variable tseg defined in scope 26460367 shadows variable of same
>> name
>>>> in
>>>> scope 4890830
>>>> Variable preparedInput defined in scope 26460367 shadows variable
>> of
>>>> same name in scope 4890830
>>>> Variable nModels defined in scope 26460367 shadows variable of
>> same
>>>> name
>>>> in scope 4890830
>>>> Variable targetId defined in scope 12182618 shadows variable of
>> same
>>>> Variable modelIn defined in scope 12182618 shadows variable of
>> same
>>>> name
>>>> in scope 4890830
>>>> Variable targetId defined in scope 21925102 shadows variable of
>> same
>>>> Variable models defined in scope 21925102 shadows variable of same
>>>> name
>>>> in scope 4890830
>>>> Swift svn swift-r3246 cog-r2721
>>>> RunID: 20100422-1609-aqv1y329
>>>> Progress:
>>>> Execution failed:
>>>>        java.lang.NumberFormatException: For input string: ""
>>>>> Wenjun,
>>>>> The first two we need are psim.loops.swift and RaptorLoops.swift,
>>>> and their corresponding runs scripts.
>>>>> We run them from the corresponding .sh sripts in scripts/run
>>>>> I'll get back to you on this tonight with more details...after I
>>>> look for my 3rd script which is RaptorLoops with an addiitonal
>>>> pre-process step that takes a raw fasta file as input. I may need
>> to
>>>> check that in from my workspace.
>>>>> - Mike
>>>>>> Hi Mike:
>>>>>>       I installed the latest version of protlib from SVN.  I'd
>> like
>>>> to
>>>>>> clarify which swift scripts are needed into the portal.
>>>>>>       These are the swift scripts in the latest protlib2:
>>>>>>       rw-r--r--  1 wwj ci-users  737 Apr 22 11:48 SwiftLib.swift
>>>>>> -rw-r--r--  1 wwj ci-users 3237 Apr 22 11:48 psim.itfixex2.swift
>>>>>> -rw-r--r--  1 wwj ci-users 2127 Apr 22 11:48 psim.itfixex1.swift
>>>>>> -rwxr-xr-x  1 wwj ci-users  509 Apr 22 11:48 psim.basicex1.swift
>>>>>> -rw-r--r--  1 wwj ci-users 2616 Apr 22 11:48 BoostThreader.swift
>>>>>> -rw-r--r--  1 wwj ci-users 1477 Apr 22 11:48 LoopLib.swift
>>>>>> -rw-r--r--  1 wwj ci-users 1193 Apr 22 11:48
>>>> BoostThreaderLib.swift
>>>>>> -rw-r--r--  1 wwj ci-users 8869 Apr 22 11:48 oops.swift
>>>>>> -rw-r--r--  1 wwj ci-users 1525 Apr 22 11:48 psim.sweepex1.swift
>>>>>> -rwxr-xr-x  1 wwj ci-users 2188 Apr 22 11:48 psim.swift
>>>>>> -rw-r--r--  1 wwj ci-users 2933 Apr 22 11:48 psim.loops.swift
>>>>>> -rw-r--r--  1 wwj ci-users 6820 Apr 22 11:48
>>>>>> RaptorLoops.hanging.swift
>>>>>> -rw-r--r--  1 wwj ci-users 2943 Apr 22 11:48 RaptorLoops.swift
>>>>>>      I guess the right swift scripts should be: psim.loops,
>>>> BoostThreader
>>>>>> and RaptorLoop.
>>>>>>      I need to create packages for both Raptor-BoostThreader and
>>>>>> RaptorLoop
>>>>>> by grouping swift scripts and mapper scripts.
>>>>>> Wenjun
>>>>>>> DataPort 2010.0421
>>>>>>> Coaster proxy issue: can Mihael automate this?
>>>>>>> Coaster proxy issue - use long proxy for now.
>>>>>>> Swift run status reporter?
>>>>>>> Adding new scripts and forms
>>>>>>> - how to shape the args? Like the email form?
>>>>>>> Need automation just for caps requests, then manual for Aashish
>>>>>> tests, then portal for Carl, Tobin et al
>>>>>>> Email notification
>>>>>>> Control over which swift the portal is running
