[Swift-devel] trouble resuming
Michael Andric
andric at uchicago.edu
Mon Sep 21 16:28:28 CDT 2009
I'm having trouble resuming swift-jobs. When resuming, it goes through
'Initializing' every single job in the workflow and just finishes without
actually picking up where it left off. Below is the swift script. Thanks
Michael
## type declarations:
type file{}
type Rscript;
## Mediator app declaration:
app (external turn) run_query (string med_args, file config, Rscript code,
file Annot){
Mediator med_args @filename(code) @filename(Annot);
## this process sets parameters and calls Mediator:
loop_query(int vert, string user, string db, string host, string
query_outline, Rscript code, file config, string subject, string h, int
beginTS, int endTS, file Annot){
string outPrefix = @strcat("gest_vs_nogest_vert",vert,h);
string med_args = @strcat("--user ","andric"," --conf ",
@filename(config)," --db ", db," --host ", host,
" --vox ", vert," --subject ", subject," --subquery tsTSVAR","
--begin_ts ",beginTS," --end_ts ",endTS,
" --query ", query_outline," --r_swift_args ",outPrefix," ",vert,"
",h," ",subject, " --outprefix ", "FAH_Q", " --r_script ", at filename(code));
external turnpt = run_query(med_args, config, code, Annot);
## needed parameters to use Mediator:
string user = @arg("user");
string db = "HEL";
string host = "tp-neurodb.ci.uchicago.edu";
file config<single_file_mapper; file="user.config">;
## mapping the R code:
Rscript code<single_file_mapper; file="Rturning/turnchi_ss2.R">;
file Annot<single_file_mapper;
file="Rturning/resampled_coding_CarStory.txt">;
## variables to move across in the foreach loops:
string declarelist[] = ["ss2"];
string hemilist[] = ["rh"];
int vertices[] = [1:155991:1];
#int vertices[] = [0:1:1];
foreach subject in declarelist{
foreach h in hemilist{
int beginTS = 0;
int endTS = 1254;
string query_outline = @strcat("SELECT SUBQUERY FROM
",subject,"TS_data",h," WHERE subject = '",subject,"' AND vertex=VOX");
foreach vert in vertices{
loop_query(vert, user, db, host, query_outline, code, config,
subject, h, beginTS, endTS, Annot);
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20090921/ac9559bf/attachment.html>
