[Swift-devel] Fwd: [gateways] Fwd: GRAM V5 Alpha 3 now available
Stuart Martin
smartin at mcs.anl.gov
Fri Sep 18 08:01:10 CDT 2009
Mike, Tibi,
Do you have more job runs that you can send to this gram5 alpha3
deployment on queen bee?
http://dev.globus.org/wiki/GRAM/GRAM5#Deployments_2
• LSU Queen Bee cluster
• https://queenbee.loni-lsu.teragrid.org:2120/jobmanager-fork
• https://queenbee.loni-lsu.teragrid.org:2120/jobmanager-pbs
Tibi, I think the problem in the past was that the head node was
rebooted and for a while the SEG was not running there. That causes
job state changes to not get propagated, so job hang in the pending
state.
-Stu
Begin forwarded message:
> From: Lukasz Lacinski <lukas at cct.lsu.edu>
> Date: September 17, 2009 11:39:34 PM CDT
> To: Stuart Martin <smartin at mcs.anl.gov>
> Cc: gateways at teragrid.org
> Subject: Re: [gateways] Fwd: GRAM V5 Alpha 3 now available
> GRAM5 Alpha3 has been installed on Queen Bee, passed successfully
> first tests and is ready for further tests. GRAM5 Alpha3 listens on
> the same port as GRAM5 Alpha2 did before (queenbee.loni-
> lsu.teragrid.org:2120/jobmanager-pbs).
> If you need help in solving any issues, please do not hesitate to
> contact me.
> Regards,
> Lukasz
> Stuart Martin wrote:
>> FYI
>>> From: Stuart Martin <smartin at mcs.anl.gov>
>>> Date: September 17, 2009 3:48:59 PM CDT
>>> To: GRAM developer <gram-dev at globus.org>, GRAM users <gram-user at globus.org
>>> >, gt-user at lists.globus.org
>>> Cc: Stuart Martin <smartin at mcs.anl.gov>
>>> Subject: GRAM V5 Alpha 3 now available
>>> Hi All,
>>> We are happy to make available a new GRAM V5 alpha 3 version for
>>> testing.
>>> http://dev.globus.org/wiki/GRAM/GRAM5#Alpha_3
>>> New features in this release:
>>> - Support for clients to get the remote application's exit code
>>> - Support for clients to get the version of the job manager
>>> Alpha 2 was deployed at 2 TeraGrid sites: LSU's Queen Bee and
>>> NCSA's Abe. Thanks to Lukasz Lacinski and Doru Marcusiu. Also,
>>> Alpha 2 got some excellent testing and feedback from Jaime Frey
>>> and Igor Sfiligoi using condor-g. Thanks Jaime and Igor. Igor
>>> ran a number of tests submitting 5000 jobs at a time. Here is a
>>> comment from Igor on the performance comparison to GRAM2:
>>> "GRAM5 can easily keep a job turnaround of around 1Hz (50 jobs/
>>> min). Compare this to the 7.5 jobs/min of GT2.
>>> Plus, it can start jobs at a 7Hz rate (450 jobs/min); GT2 best
>>> case scenario was 0.5Hz (33 jobs/min).
>>> (note: the comparison is not really apple to apple due to missing
>>> file transfer)"
>>> We would encourage GRAM users to install and test this new Alpha 3
>>> version. Please send your feedback to gram-dev at globus.org or to
>>> me directly.
>>> Thanks for your support!
>>> - GRAM development team
>> Gateways mailing list
>> Gateways at teragrid.org
>> http://teragrid.org/mailman/listinfo/gateways
