[Swift-devel] Swift and BGP plots
Ioan Raicu
iraicu at cs.uchicago.edu
Thu Oct 29 12:04:00 CDT 2009
hmmm, any recommendation on how to parse them out from each other? My
simple cat and grep probably won't work. Is there a patterns at least,
on the number of dashes "-"?
Ioan
Mihael Hategan wrote:
> On Thu, 2009-10-29 at 09:30 -0500, Ioan Raicu wrote:
>>> Nope. 64K.
>> OK, it would be good to look at why we have double the # of tasks. It
>> must be my filtering of the Swift log. Here was my filtered log:
>> http://www.ece.northwestern.edu/~iraicu/scratch/logs/dc-4000-active-completed.txt
> Both the coaster service log and swift log go to the same place in that
> case. You'll see a difference in the way the task IDs look. That's
> something you can use.
> This is a task on the swift side:
> identity=urn:0-1-11475-1-1-1256524749943
> This is on the coaster side:
> identity=urn:1256524750479-1256524791529-1256524791530
>>> It depends whether you count from the time the partition boots or from
>>> the time swift starts. We could count the queue/partition boot time, but
>>> that doesn't tell us much about swift. On the other hand, if we don't
>>> there's still some submission happening during that time, so that
>>> counts.
>> I count from where the log starts. There is about 20 seconds of
>> inactivity at the beginning of the log, but at around 20 sec in one
>> log, and 24 sec in the other log, 1 job is submitted and running.
> That's the worker block. It's "running" in that cobalt says so, but it's
> booting.
>> At about 120 second into the run, the floodgate is opened and many
>> jobs are submitted and start running. So, should we count from time 0,
>> 20, or 120?
> 100. The 20 seconds of activity in the beginning are real
> swift/submission overhead. The waiting until the partition boots isn't.
>> I guess its all about what you are trying to measure and show. In all
>> cases, I think the workers were provisioned, its just a matter of how
>> much of the Swift overhead you want to take into account I think.
>>> The numbers for Falkon, were the workers started already?
>> Yes, the workers were already provisioned in that case.
>>>> Not quite the 90%+ efficiencies when looking at a per task level, but
>>>> still quite good!
>>> I'm not quite sure what's happening. Maybe I wasn't clear. Though I was.
>>> Is there some misunderstanding here about the different things being
>>> measured and how?
>> No. The real way to compute efficiency is to use the end-to-end time
>> of the real run compared to the ideal run. The other efficiency I
>> sometimes throw out is the per task efficiency, where you take the
>> average real run time of all tasks, and compare it to the ideal time
>> of a task. This second measure of efficiency is usually optimistic,
>> but it allows us to measure efficiency between various different runs
>> that might be too difficult to compare using the traditional
>> efficiency metric.
> Again, I believe the latter to be arbitrary. That's because according to
> it you can have very low efficiencies yet linear speedups. In addition,
> I see no literature to use it.
> If you want to use such an arbitrary measure, fine. Please don't use it
> on this.
Ioan Raicu, Ph.D.
NSF/CRA Computing Innovation Fellow
Center for Ultra-scale Computing and Information Security (CUCIS)
Department of Electrical Engineering and Computer Science
Northwestern University
2145 Sheridan Rd, Tech M384
Evanston, IL 60208-3118
Cel: 1-847-722-0876
Tel: 1-847-491-8163
Email: iraicu at eecs.northwestern.edu
Web: http://www.eecs.northwestern.edu/~iraicu/
https://wiki.cucis.eecs.northwestern.edu/
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20091029/f75b2550/attachment.html>
