[Swift-devel] Swift and BGP plots
Ioan Raicu iraicu at cs.uchicago.edu
Wed Oct 28 23:11:33 CDT 2009
Mihael,
Did you figure out why I am seeing 8K and 12K active tasks, when we only
had 4K and 6K CPU cores? Were there really 128K tasks in the workflow?
Just want to make sure the log conversion worked as expected.
Also, assuming there were really 128K tasks of 60 sec each, and 8K CPUs,
the ideal time to complete the run 4K would be 960 sec. Run4K ran in
1183 sec, giving us an end-to-end efficiency of 81%.
For the run6K, the ideal time was 640 sec, so with an actual time of
884, we got an end-to-end efficiency of 72%.
Not quite the 90%+ efficiencies when looking at a per task level, but
still quite good!
Ioan
Ioan Raicu wrote:
> Alright, here it is again:
> 4K run: Average Task Execution Time (ms): 61946.37017455522 +/-
> 4884.571426229936
> Efficiency: 96.8%
> 6K run: Average Task Execution Time (ms): 64415.056860142206 +/-
> 6090.13371098675
> Efficiency: 93.1%
> These both look pretty nice.
> Now, the only thing that still looks odd, is that in the 4K run, I see
> 8K active tasks, and in the 6K run I see 12K active tasks. I also have
> 128K tasks in total. Are my plots off by 2X somehow?
> Ioan
> 4K run:
> 6K run:
> Ioan Raicu wrote:
>> Great!
>> Mihael Hategan wrote:
>>> On Tue, 2009-10-27 at 15:10 -0500, Ioan Raicu wrote:
>>>> Which of these should I use in finding the Complete event? Or are they
>>>> equivalent?
>>>> 2009-10-25 21:42:10,717-0500 INFO  LateBindingScheduler
>>>> Task(type=JOB_SUBMISSION, identity=urn:0-1-12173-1-1-1256524749960)
>>>> Completed. Waiting: 3606, Running: 16387. Heap size: 1003M, Heap free:
>>>> 66M, Max heap: 1024M
>>>> 2009-10-25 21:42:10,608-0500 DEBUG TaskImpl Task(type=JOB_SUBMISSION,
>>>> identity=urn:1256524752479-1256524793584-1256524793585) setting status
>>>> to Completed
>>> It's probably best if you used TaskImpl for both Active and Completed.
>> Ioan Raicu, Ph.D.
>> NSF/CRA Computing Innovation Fellow
>> Center for Ultra-scale Computing and Information Security (CUCIS)
>> Department of Electrical Engineering and Computer Science
>> Northwestern University
>> 2145 Sheridan Rd, Tech M384
>> Evanston, IL 60208-3118
>> Cel:   1-847-722-0876
>> Tel:   1-847-491-8163
>> Email: iraicu at eecs.northwestern.edu
>> Web:   http://www.eecs.northwestern.edu/~iraicu/
>>        https://wiki.cucis.eecs.northwestern.edu/
>> Swift-devel mailing list
>> Swift-devel at ci.uchicago.edu
>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
> Ioan Raicu, Ph.D.
> Cel:   1-847-722-0876
> Tel:   1-847-491-8163
Ioan Raicu, Ph.D.
Cel:   1-847-722-0876
Tel:   1-847-491-8163
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20091028/178d7181/attachment.html>
Name: not available
Type: image/jpeg
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20091028/178d7181/attachment.jpe>
Name: not available
Type: image/jpeg
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20091028/178d7181/attachment-0001.jpe>
