[Swift-devel] Re: IO overheads of swift wrapper scripts on	BlueGene/P
    Michael Wilde
    wilde at mcs.anl.gov
    Fri Oct 23 16:19:49 CDT 2009
Cool, Allan, thanks for the update. Especially for our CDM work, it
would be useful to go back and figure out where the lengthy delays were
coming from, as that helps justify CDM. I suspect its contention in the
creation of jobdirs on shared storage, or contention within a jobdir, or
both. We'll want to see how this overhead grows with scale; it doesnt
seem to take much parallelism to cause bad degradation with the default
data management.
- Mike
On 10/23/09 4:14 PM, Allan Espinosa wrote:
> Hello,
> I just tried  Mike's swift build in
> /home/falkon/swift/src/cog/modules/swift/dist/swift-svn/bin/swift .
> My workflow ran for 838 seconds.  This is pretty comparable to a
> falkon-only run of 829 seconds.
> I guess the patches (local CN jobdir) fixes things.
> thanks Mike!
> -Allan
> 2009/10/16 Allan Espinosa <aespinosa at cs.uchicago.edu>:
>> The attached graph looks interesting. The green on the left shows the
>> 192 job workload using the straight falkon client. The right one is
>> through swift.  Using pure falkon the total time for the workload is
>> at around 814 seconds while the swift workflow took 1520 seconds.  In
>> some repeats of the same run, Swift took 3078 seconds.
