[Swift-devel] [Fwd: re: IO overheads of swift wrapper scripts on BlueGene/P (fwd)]
Michael Wilde
wilde at mcs.anl.gov
Mon Oct 19 07:59:12 CDT 2009
On 10/19/09 12:39 AM, Mihael Hategan wrote:
> On Mon, 2009-10-19 at 00:32 -0500, Mihael Hategan wrote:
>> -------- Forwarded Message --------
>> From: Ben Clifford <benc at hawaga.org.uk>
>> To: hategan at mcs.anl.gov
>> Subject: re: IO overheads of swift wrapper scripts on BlueGene/P (fwd)
>> Date: Mon, 19 Oct 2009 03:28:07 +0000 (GMT)
>> i sent this earlier then i remembered that no one seems to
>> moderate-approve my swift devel postings ever...
I do, when I see them.
> I don't seem to be getting those.
> On this topic, why did we unsubscribe one of swift's committers from the
> swift mailing list(s)?
I thought this was done by Ben. He's certainly welcome to subscribe.
>> ---------- Forwarded message ----------
>> Date: Mon, 19 Oct 2009 01:59:44 +0000 (GMT)
>> To: swift-devel at ci.uchicago.edu
>> swift r2970 changed copying outputs to a hard-link of outputs to improve
>> performance at the output stage. you might be interested to see how that
>> works.
>> (also, don't use the same runid for different runs. you'll get into
>> trouble somehow sooner or later. )
>> r2970 | benc | 2009-06-22 23:40:53 +1000 (Mon, 22 Jun 2009) | 6 lines
>> Make wrapper use mv to stage out files to shared directory rather than cp.
>> This should be faster when the job directories are on the same filesystem
>> as the site shared cache.
>> (suggested by tuecke)
> Right. We're already using that. mv, on the same fs, would just make an
> entry in the new directory pointing to the same data instead of
> duplicating the data. Though I suppose this depends on the FS.
> However, we have to filesystems here, so it doesn't apply.
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
