[Swift-devel] [Fwd: re: IO overheads of swift wrapper scripts on BlueGene/P (fwd)]
Mihael Hategan
hategan at mcs.anl.gov
Mon Oct 19 00:32:10 CDT 2009
This from Ben.
-------- Forwarded Message --------
To: hategan at mcs.anl.gov
Subject: re: IO overheads of swift wrapper scripts on BlueGene/P (fwd)
Date: Mon, 19 Oct 2009 03:28:07 +0000 (GMT)
i sent this earlier then i remembered that no one seems to
moderate-approve my swift devel postings ever...
---------- Forwarded message ----------
Date: Mon, 19 Oct 2009 01:59:44 +0000 (GMT)
To: swift-devel at ci.uchicago.edu
swift r2970 changed copying outputs to a hard-link of outputs to improve
performance at the output stage. you might be interested to see how that
works.
(also, don't use the same runid for different runs. you'll get into
trouble somehow sooner or later. )
r2970 | benc | 2009-06-22 23:40:53 +1000 (Mon, 22 Jun 2009) | 6 lines
Make wrapper use mv to stage out files to shared directory rather than cp.
This should be faster when the job directories are on the same filesystem
as the site shared cache.
(suggested by tuecke)
