[Swift-devel] IO overheads of swift wrapper scripts on BlueGene/P
Allan Espinosa aespinosa at cs.uchicago.edu
Sun Oct 18 09:24:35 CDT 2009
swift does extra moves from job directory to work directory.  which
takes long in this case.
-Allan
2009/10/18 Ioan Raicu <iraicu at cs.uchicago.edu>:
> Hi Allan,
> I don't remember, but your Falkon only run seemed to run OK, right? Didn't
> that also produce the output files Swift is producing? Or is Swift doing an
> extra step, to copy/move files from one place to another after the
> computation terminates, which is the thing that takes so long? Just trying
> to understand the difference between the Falkon only run and Swift run.
> Ioan
> Ioan Raicu, Ph.D.
> NSF/CRA Computing Innovation Fellow
> Center for Ultra-scale Computing and Information Security (CUCIS)
> Department of Electrical Engineering and Computer Science
> Northwestern University
> 2145 Sheridan Rd, Tech M384
> Evanston, IL 60208-3118
> Cel:   1-847-722-0876
> Tel:   1-847-491-8163
> Email: iraicu at eecs.northwestern.edu
> Web:   http://www.eecs.northwestern.edu/~iraicu/
>        https://wiki.cucis.eecs.northwestern.edu/
> Allan Espinosa wrote:
> Here I tried one directory per job (Q0000130).  3 output files are
> expected per directory which are produced by a single job:
> Progress  2009-10-17 20:53:56.943503000-0500  LOG_START
> _____________________________________________________________________________
>         Wrapper
> Job directory mode is: link on shared filesystem
> DIR=jobs/7/blastall-715ul5ij
> EXEC=/home/espinosa/workflows/jgi_blastp/blastall_wrapper
> STDIN=
> STDOUT=home/espinosa/workflows/jgi_blastp/oldtests/test3.2.7_3cpn.64ifs.192cpu/output/D0000000/Q0000130/out_Q0000130.sout
> STDERR=home/espinosa/workflows/jgi_blastp/oldtests/test3.2.7_3cpn.64ifs.192cpu/output/D0000000/Q0000130/out_Q0000130.serr
> DIRS=home/espinosa/workflows/jgi_blastp/oldtests/test3.2.7_3cpn.64ifs.192cpu/output/D0000000/Q0000130
> INF=
> OUTF=home/espinosa/workflows/jgi_blastp/oldtests/test3.2.7_3cpn.64ifs.192cpu/output/D0000000/Q0000130/out_Q0000130.out^home/espinosa/workflows/jgi_blastp/oldtests/test3.2.7_3cpn.64ifs.192cpu/output/D0000000/Q0000130/out_Q0000130.serr^home/espinosa/workflows/jgi_blastp/oldtests/test3.2.7_3cpn.64ifs.192cpu/output/D0000000/Q0000130/out_Q0000130.sout
> KICKSTART=
> ARGS=-p blastp -m 8 -e 1.0e-5 -FF -d /dataifs/nr -i
> /intrepid-fs0/users/espinosa/persistent/datasets/nr_bob/queries/mock_2seq/D0000000/SEQ0000130.fasta
> -o
> ARGC=13
> Progress  2009-10-17 20:53:58.656335000-0500  CREATE_JOBDIR
> Created job directory: jobs/7/blastall-715ul5ij
> Progress  2009-10-17 20:54:05.204962000-0500  CREATE_INPUTDIR
> Created output directory:
> jobs/7/blastall-715ul5ij/home/espinosa/workflows/jgi_blastp/oldtests/test3.2.7_3cpn.64ifs.192cpu/output/D0000000/Q0000130
> Progress  2009-10-17 20:54:15.498666000-0500  LINK_INPUTS
> Progress  2009-10-17 20:54:19.900786000-0500  EXECUTE
> Moving back to workflow directory
> /fuse/intrepid-fs0/users/espinosa/scratch/jgi-blastp_runs/blastp-test3.2.7_3cpn.64ifs.192cpu
> Progress  2009-10-17 21:20:23.390800000-0500  EXECUTE_DONE
> Job ran successfully
> Progress  2009-10-17 21:31:11.179664000-0500  COPYING_OUTPUTS
> Progress  2009-10-17 21:37:14.539569000-0500  RM_JOBDIR
> Progress  2009-10-17 21:38:24.220130000-0500  END
> COPYING_OUTPUTS still take time.
> 2009/10/17 Michael Wilde <wilde at mcs.anl.gov>:
> Remember that any situation in which multiple IONs modify the same file or
> directory (ie by creating files or directories in the same parent directory)
> will cause severe contention and performance degradation on any GPFS
> filesystem.
> In addition to creating many directories, you need to ensure that no single
> file or directories is likely to ever be written to from multiple client
> nodes (eg IONs on the BG/P) concurrently.
> This workload is just over 1 PSET so there are no other IONs
> contending over the directories.
> Have you done that in this workload, Allan?
> - Mike
> On 10/17/09 2:59 AM, Allan Espinosa wrote:
> I was using 1000 files  (or was it 3000?) per directory. it looks like
> i need to lower my ratio...
> -Allan
> 2009/10/16 Mihael Hategan <hategan at mcs.anl.gov>:
> On Fri, 2009-10-16 at 21:07 -0500, Allan Espinosa wrote:
> Progress  2009-10-16 18:00:33.756364000-0500  COPYING_OUTPUTS
> Progress  2009-10-16 18:08:19.970449000-0500  RM_JOBDIR
> Grr. 8 minutes spent COPYING_OUTPUTS.
> What would be useful is to aggregate all the access that happened on
> that FS from all the relevant jobs, to see the exact thing that causes
> contention. I strongly suspect it's
> home/espinosa/workflows/jgi_blastp/test3.4.7_3cpn.32ifs.192cpu/output/
> Pretty much all the outputs seem to go to that directory.
> I'm afraid however that the information in the logs is insufficient.
> Strace with relevant options (for fs calls only) may be useful if you
> want to try.
> Alternatively, you could try to spread your output over multiple
> directories and see what the difference is.
> Also, it may be interesting to see the dependence between the delay and
> the number of contending processes. That is so that we know the limit of
> how many processes we can allow to compete for a shared resource without
> causing too much trouble.
> Mihael
